.SSA/.ASS Subtitles
Hello,
I know Plex will play plain text .SRT subtitles without transcoding.
Do .SSA/.ASS subtitles with embedded fonts need transcoding?
Thanks.
On most devices - yes.
As do most image based subs - whatever they are.
Okay, thanks.
So will ssa sub’s without embedded fonts need transcode aswell?
If it’s an image based sub - yes.
Apparently it’s easy to overlay a text sub on the video.
An image has to be burned in.
Some devices/clients may be able to handle those without transcoding - Shield/PMP may, don’t know really - but most devices will require a transcode for image based subs.
Awesome. Mine are not image based. Just plain text with a little formatting- font size and a big increase border around the words but no special placing on the screen.
SSA subs are text-based.
But the format is very powerful. It supports colorization of every letter, color gradients, drop shadows, animation with transitional effects and more.
So parser needs to be very powerful. The little JavaScript library which is used by most clients for subtitle rendering is not able to render that.
The one in the web app supports ass subs with all formatting stripped away - which yields often bizarre results when playing Anime, which often use the special abilities of the ASS format very heavily.
Real ASS support is only available in PMP and OpenPHT/Kodi - and the Plex transcoder.
Yeah… To bad. It seems that the video DOES get transcoded from little as font size and adding a thicker border. That sucks.
[edit] the following post has been posted to the Tips & Tricks forum in an extended version: https://forums.plex.tv/discussion/284922/customizing-subtitle-appearance-in-plex-media-player-pmp
If you use PMP, you can tune the subtitles to your liking.
The AV engine in PMP (MPV) supports a lot of parameters.
Create a text file named mpv.conf beside the plexmediaplayer.conf file.
Now we add the line
--sub-border-size=6
to it, which defines the border around subtitles to be 6 pixels thick
Normally, this option doesn’t apply to ASS subtitles, because they define their own border style. If you want to treat ASS subs with the same black border, you need additionally the line --sub-ass-force-margins
now, whe’re adding the line
--sub-bold=yes
and now --sub-spacing=1
Don’t mind the black borders on top and bottom of the picture, my screen is 1200 pixels high, instead of 1080.
Thanks, but I don’t use PMP. I have a Roku. But yeah, the last pic above is very close to what I see. Mine is a bit bigger and thicker. HA!! I crack myself up!!
Roku will also let you ‘customize’ subs - to some degree.
In the ‘Captions’ area off of Settings from the Main Roku Menu.
Yeah, I was hoping that all could be done without any manual setting changes and such. Afterall, I do way to much manual crap outside of Plex I really don’t want to start doing the same within Plex. But that’s nice to know if I really have a need.
I understand Roku wants to centralize these settings. So even if Plex wanted to incorporate these settings into the Plex channel, it isn’t allowed to do so by Roku.
