Hello all @ChuckPa could you also reset my cert please? After you reset I just need to restart the server?
When I try to play anything in samsung or LG it doesn’t play anything that needs to be transcoded ( due to codecs ) unless I change settings to allowed unsecure connections
I did try to remove cert from cache directory and after restart pms so it would generate a new one, but issue still the same
error:
Hi can you please restart my server as well, i’m having the same error on rasp plex connection
CERT: incomplete TLS handshake from [::ffff:xxx.xxx.x.xxx]:38722: sslv3 alert certificate expired
Hello @ChuckPa , if I am getting the following error only from certain devices such as MacOS Chrome web app and Playstation Plex app, but it’s working fine on PC Chrome web app and iOS Plex app, would a “certificate reset” fix the problem? Please advise. Thank you.
Thanks for your prompt @ChuckPa ! I have already tried restarting the host several times before I reached out, hoping that will somehow fix itself. Too bad it didn’t work.
Let me try reinstalling the Playstation app.
When you say ‘Apple products’, does it include Chrome browser on Mac OSX because both Chrome and Safari didn’t work? But Chrome on PC (Windows 10) works fine so far (knock on wood).
I’m not fully understanding what this issue is. Isn’t the sslv3 cert given out by Plex to servers and/or clients? If it’s an expired issue then renewing it should fix it right? Does the Samsung firmware need updating in order to get a new cert? Or is this cert from Samsung to the smart TVs and they aren’t allowing it to update?
If it is just on the Plex side which needs a renewed cert could you please reset mine as well?
Thanks in advance,
Thank you. This means I can raise hell then with Samsung for either purposefully or haphazardly creating TV software that creates a partial planned obsolescence situation. Sounds like they really don’t need new TV firmware but rather to maintain a minor service, license renewal, for existing products. Which to me and knowing about SSL certs is not a function of continued support unless the SSL cert protocol needs modified which has been around for a long time and should be working for a long time more. An analogy being a domain name’s IP changed and instead of updating the A record’s IP address they just say ‘we no longer support that TV.’
