SSL Certificate Errors
Is there a firewall / virus scanner / port filter in there somewhere ?
The transcode is starting, running, then gets terminated due to the connection being closed.
Nov 22, 2021 21:31:22.405 [15532] DEBUG - [Transcode/67B81923-F3D4-4F26-A295-FE580519D569] Asked for segment 262 from session.
Nov 22, 2021 21:31:22.405 [15532] DEBUG - [Transcode/67B81923-F3D4-4F26-A295-FE580519D569] Returning segment 262 from session
Nov 22, 2021 21:31:22.405 [15532] DEBUG - Content-Length of C:\Users\Administrator\AppData\Local\Plex Media Server\Cache\Transcode\Sessions\plex-transcode-67B81923-F3D4-4F26-A295-FE580519D569-f008880d-5329-4c88-837e-b5e1a96e286b\media-00262.ts is 956749 (of total: 956749).
Nov 22, 2021 21:31:22.405 [15532] ERROR - Caught exception trying to stream file: C:\Users\Administrator\AppData\Local\Plex Media Server\Cache\Transcode\Sessions\plex-transcode-67B81923-F3D4-4F26-A295-FE580519D569-f008880d-5329-4c88-837e-b5e1a96e286b\media-00262.ts: write: protocol is shutdown
Nov 22, 2021 21:31:22.405 [10324] DEBUG - Completed after connection close: [192.168.1.53:49540] 500 GET /video/:/transcode/universal/session/67B81923-F3D4-4F26-A295-FE580519D569/base/00262.ts (7 live) TLS 0ms 0 bytes (pipelined: 4)
Nov 22, 2021 21:31:22.405 [10324] DEBUG - Removed transcode data consumer, active count 272 => 272
Does this make any sense to you?
Was playing:
Nov 22, 2021 21:31:32.199 [15532] DEBUG - Client [7812C669-15A5-42D4-8E32-16BD00ACB3CD] reporting timeline state playing, progress of 1102667/3159667ms for guid=, playbackTime=1054408ms ratingKey=15519 url=, key=/library/metadata/15519, containerKey=, metadataId=15519, source=
Nov 22, 2021 21:31:32.200 [15532] DEBUG - Play progress on 15519 'The Portrait' - got played 1102667 ms by account 1!
Nov 22, 2021 21:31:32.202 [15532] DEBUG - [Now] User is flyveleder (ID: 1)
Nov 22, 2021 21:31:32.202 [15532] DEBUG - [Now] Device is tvOS (Martin (3353)).
Nov 22, 2021 21:31:32.202 [15532] DEBUG - [Now] Profile is tvOS
Nov 22, 2021 21:31:32.202 [15532] DEBUG - [Now] Updated play state for /libra
Hi, I hope I’m posting in the right topic.
I’ve noticed I lost connection to my Plex server this afternoon but not sure what triggered this.
I can access the content using local Web App but cannot from plex.tv nor Android App.
Plex version Version 1.24.5.5173
Tried sign out / sign in and service restart but issue still present .
Logs show some error regarding certificate :
CERT: Error acquiring new certificate: Failed to retrieve cert from plex.tv: 429,
CERT: Error acquiring new certificate: Failed to upload CSR: 429, <?xml version="1.0" encoding="UTF-8"?>
Thanks for the help.
@grojojo
It looks like you reinstalled or signed out / lost info from Preferences.xml.
That created a new server of the same name.
That new server then hammered on Plex.tv for a certificate and Plex.tv throttled it.
I have reset the 429 lockout for now.
Restart the server.
If it does not respond correctly, make a tar.gz / ZIP of the “Logs” directory and attach here.
It looks like I may be having a certificate issue as well.
Nov 25, 2021 17:56:44.643 [0x7ffb226156e8] DEBUG - [CERT] Installed certificate with fingerprint xx:xx.
Nov 25, 2021 17:56:50.535 [0x7ffb1cda5b38] DEBUG - CERT: Certificate expires soon, fetching a new one.
Nov 25, 2021 17:56:50.535 [0x7ffb1cda5b38] DEBUG - HTTP requesting GET Sign In | Plex
Nov 25, 2021 17:56:50.676 [0x7ffb1cda5b38] DEBUG - HTTP/1.1 (0.1s) 200 response from GET Sign In | Plex (reused)
Nov 25, 2021 17:56:50.691 [0x7ffb1cda5b38] DEBUG - HTTP requesting PUT https://plex.tv/api/v2/devices/xxxxx/certificate/csr?reason=expiring&invalidIn=2457987
Nov 25, 2021 17:56:50.834 [0x7ffb1cda5b38] DEBUG - HTTP/1.1 (0.1s) 429 response from PUT https://plex.tv/api/v2/devices/xxxxx/certificate/csr?reason=expiring&invalidIn=2457987 (reused)
Nov 25, 2021 17:56:50.850 [0x7ffb1cda5b38] ERROR - CERT: Error acquiring new certificate: Failed to upload CSR: 429,
Nov 25, 2021 17:58:08.446 [0x7ffb1d20cb38] DEBUG - CERT: incomplete TLS handshake from 192.168.112.15:11262: sslv3 alert certificate unknown
Is it possible to try to get a reset?
@qw741234
May I have a ZIP of your logs please ? ( a tar.gz of the Logs directory is just as good )
Not the original users but I’m also having certificate issues today. Same 429 issues as have been posted above. I’m installing Plex via Docker and claiming during container setup. I’ve had one successful attempt but it seems most attempts are failing. These are the Logs from a server that have basically only been claimed and nothing else
Plex Media Server Logs_2021-11-26_02-22-39.zip (194.5 KB)
Hopefully this helps. Thank you!
@qw741234
I have cleared the Plex.tv throttling AND reset your certificate.
Please restart your server.
Next, after the server restarts, restart your apps.
@niayh
I have reset your certificate.
I have also removed 20 dead servers of the same name as your container which haven’t been seen in at least 9 months.
I have cleaned as much as I can but I do request you clean up the rest from “Settings - Authorized Devices - Server (dropdown)”
For now, please restart your server.
In the future, please consider keeping the server’s data rather than starting over with each new version?
@ChuckPa could you reset mine please?
@schiraldihno
Your certificate is valid::
	Valid	Wed, 24 Nov 2021 17:34:09 +0000	Wed, 24 Nov 2021 17:35:08 +0000
May I see your logs?
PS: It is not necessary to flag your posts in this thread. I am notified of every post.
@ChuckPa Indeed, when I first noticed issue on Plex, linux service was showing error accessing Preferences.xml. It was actually empty. I restarted server and it generates a new .xml file but then get this certificate issue. I’ve restarted the server following your action but still not able to connect securely from remote. I do not see any particular error on service status.
Plex Media Server Logs_2021-11-26_08-13-24.zip (1.6 MB)
Hmmm not sure what happened but it is now working from Android App but sill not from app.plex.tv.
Hi
seems I have the common cert throttling using Plex web only (restarted the server, did not change anything)
Here are the logs
It seems to have happened yesterday or the day before. Any idea why ?
Thank you !
Hi there,
I have the same problem ( server unavailable due to to insecure connection ) It has worked for years but now it is broken sine 2 or 3 days…
Only one of my server has the problem it is hosted as vmhost on 192.168.0.48. It still work on Apple TV but not on the app.plex.tv
plexlog.zip (10.7 KB)
Plex Media Server Logs_2021-11-26_15-52-26.zip (1.9 MB)
Thx a lot
Thank you, this resolved the issue. I’m now able to use the encrypted connection again.
Hi Chuck,
My plex has been not working for the past 4 months. Right after I messaged you it started working again? I have no idea how but thank you.
I’m getting these two errors as well. Would a reset resolve my issue?
Nothing network wise has changed. I rebooted my server it and stopped working.
CERT: Error acquiring new certificate: Failed to upload CSR: 429, <?xml version="1.0" encoding="UTF-8"?> errors error code=“1003” message=“API rate limit exceeded”/ /errors
@ErmakDrixx
I’ve removed the 429 trigger.
Restart the server please.
@schiraldihno
I have the ability to go into your account at Plex.tv
  1. See the servers and players on your account
  2. Examine the certificate
  3. Reset the certificate if needed.
