Hello @ChuckPa
Can you please reset my cert. I believe I’m having the same error. I’m on windows but it shouldn’t matter I think I just need my cert reset.
CERT: incomplete TLS handshake from [::ffff:156.57.138.199]:56802: sslv3 alert certificate unknown
Thanks for your help!
Its on all devices at my friends home!
And which log did you need? Because there are several in my plex folder! Or should i create a new one? With friend in or…?
Browsers connecting to the server via the webapp are experiencing:" app.plex.tv is unable to connect to SERVER_NAME securely. "
Screenshot of error on my friends mac with chrome browser.
Thanks for your commitment!
This ip is not from me and my friends! Also not in the ip range from my router! I haven‘t seen this one before!
In my browser their comes this
Sorry! I also don‘t know! But this is showing me if i take this ip,(I’ve never seen before)
161.97.119.209:80 you have marked in blue, into the browser to have a look about!
About geo blocking, i remember my friend tried a time ago to come in with VPN(not my home vpn) and it worked sometimes! maybe one of the reasons
Thank you very much for the help!
I get these error messages: CERT: incomplete TLS handshake from 162.246.205.27:33073: wrong version number
The IP address is changing. First it were ipv6, after I disabled that only ipv4. I did not change any settings, Plex is running with standard settings. After some minutes or hours the server is not reachable and I have to restart it. Nobody is streaming when these error messages appear.
Since what I think is yesterday my server is struggeling with the certificate of plex.tv. Seems to be no problems on my client machines.
I see the following error in the log:
SSL: no alternative certificate subject name matches target host name ‘plex.tv’
I don’t know. This IP address is probably from the US. I’m based in Europe so that shouldn’t happen. I do get flooded by these messages but from different IP addresses.
I just finished moving my Plex server from a Windows machine to a Fedora machine. I’m getting this error in the console logs:
CERT: incomplete TLS handshake from [::ffff:172.16.0.9]:54868: sslv3 alert bad certificate
This is the IP of the Windows machine (no longer running Plex Server). Does something need reset or did I copy something over in the config that I shouldn’t have?
