Well thanks for clarifying its not the cert.
Port is forwarded and checks out, firewall has the right exceptions but also I have tested with it off.
P:\ is the data drive for plex containing all the meta.
Other than Tautulli I have no plugins.
Not sure where the issue is.
I just tested from my work network (separate isp) and works just fine. Just doesn’t want to work from my cell isp which is the only other one I can test with currently.
Edit: after some searching it appears to be IPv6 issue related, connecting from ipv6 device to the server. not sure if there’s a fix?
Wont take up anymore on this thread unless you have any suggestions.
My router has acceptions to allow ipv6 inbound connections.
Plex is set to allow allow ipv6 connections.
My cell carrier must have switched to ipv6 recently as I am getting ipv6 address on my phone when connected to LTE data. And cannot connect to plex from my phone via Web or plex app.
After a few days of testing it turns out everything is working for everyone now after cert update but my phone on carrier data does not, works fine on any wifi connections.
Can’t figure it out
Samsung s21 ultra.
I’ve read few people are having issues playing video with a temp fix but I can’t even connect to the server.
Hello,
so a buddy of mine installed plex media server on my Nvidia Shield, he showed me how to use it via iPad for the settings and stuff, that was at his home and working fine, now after I plugged everything on my TV at my place, I tried to access Plex via iPad and App and via Url, I get this unsecure connection screen I saw posted earlier in this thread, any suggestions what I need to do?
Been kinda busy with the holiday here. I have a bit of time tonight.
I’ve looked at the server. The certificates are correct
What I see of significance:
CREATED 8 DAYS AGO
LAST SEEN ABOUT 8 HOURS AGO
PUBLISHED NO
LOCAL ADDRESSES 192.168.0.16
CERTIFICATE: Valid Fri, 17 Dec 2021 15:37:43 +0000 Fri, 17 Dec 2021 15:37:53 +0000
Is the LAN address correct for this new location?
Is the correct account being used to sign into it or is it registered to another account?
Not being secure tells me it’s having something wrong with certificates or DNS authentication.
In either case, i am going to need to see the DEBUG log files from the server
Thanks for your help, well getting the logs might be a problem, in explaining him how to get them from the shield, he has no computer besides his iPad.
But I will figure something out.
Please Help! I also seeing a numbers of this
„ CERT: incomplete TLS handshake from [::ffff:45.143.200.118]:64929: wrong version number“.
Also a friend with fiber network didn‘t come in to my server, only „not direct“!
Over radio network are no problems! Plex is newest beta! Thanks for your time!
The certs are new what shall i do!
