Trying again with fresh thread hoping that a more concise request yields more help:
I had to change my Plex password and since then SSL on my local PMS console no longer works. I followed the troubleshooting guide for the “no soup for you” issue but it didn’t help. My final act of desperation was to turn off secure connections via the HtTP console and delete the client token for my local PMS console but all that accomplished was removed all “knowledge” of my PMS server media from app.plex.tv as well as via the HTTP console on the local PMS server. Neither knows my PMS server’s existence but I can now access media from other clients on the LAN that still had a placeholder for my PMS but all play count info was lost so all media is shown as unwatched. Ouch.
In my other post there is more background (it is “as it happened” so it’s tedious”) but hopefully this post will be enough to tell if my PMS is salvageable or of I have to remove my installation and start over. (Again.) And, if I do have to nuke it from orbit (again) is there some way to preserve what remains of my metadata this time?
Finally, for what it’s worth, here are my PMS logs at startup. PMS appears to be attempting to connect to my public IP (I put “xxx” the last octet for what it’s worth) and it is attempting to ”parse device schema” from a port on my LAN gateway. Debug logs show attempts to connect to the remote access port (32400) on loopback but fails.
Feb 09, 2020 12:26:01.551 [0x7f9a383a1700] INFO - Plex Media Server v1.18.6.2368-97add474d - Ubuntu PC x86_64 - build: linux-x86_64 debian - GMT -08:00
Feb 09, 2020 12:26:01.551 [0x7f9a383a1700] INFO - Linux version: 18.04.3 LTS (Bionic Beaver), language: en-US
Feb 09, 2020 12:26:01.551 [0x7f9a383a1700] INFO - Processor Intel(R) Core(TM) i7-7700T CPU @ 2.90GHz
Feb 09, 2020 12:26:01.551 [0x7f9a383a1700] INFO - /usr/lib/plexmediaserver/Plex Media Server
Feb 09, 2020 12:26:04.877 [0x7f9a127fc700] ERROR - getaddrinfo(172-17-0-1.abcdefghijklmnopqrstuvwxyz012345.plex.direct) failed: -2
Feb 09, 2020 12:26:06.235 [0x7f9a2da7a700] ERROR - Error issuing curl_easy_perform(handle): 35
Feb 09, 2020 12:26:06.235 [0x7f9a2da7a700] WARN - HTTP error requesting GET https://199-83-220-xxx.4f26111badbf478491f39c2658e1cd34.plex.direct:32400/identity (0, No error) (OpenSSL SSL_connect: SSL_ERROR_SYSCALL in connection to 199-83-220-xxx.4f26111badbf478491f39c2658e1cd34.plex.direct:32400 )
Feb 09, 2020 12:26:07.866 [0x7f9a1fbdd700] INFO - Refreshing paths watched by LibraryUpdateManager
Feb 09, 2020 12:26:08.054 [0x7f99ecff9700] ERROR - [Notify] Failed to add watch for "/mnt/plex_media/TV Shows/Rick and Morty/Season 01" (13: Permission denied)
Feb 09, 2020 12:26:08.054 [0x7f99ecff9700] ERROR - [Notify] Failed to add watch for "/mnt/plex_media/TV Shows/Rick and Morty/Season 02" (13: Permission denied)
Feb 09, 2020 12:26:08.055 [0x7f99ecff9700] ERROR - [Notify] Failed to add watch for "/mnt/plex_media/TV Shows/Rick and Morty/Season 04" (13: Permission denied)
Feb 09, 2020 12:26:12.836 [0x7f9a1e3da700] ERROR - Error issuing curl_easy_perform(handle): 52
Feb 09, 2020 12:26:12.836 [0x7f9a1e3da700] WARN - HTTP error requesting GET http://192.168.250.1:1990/0bf9a260-52cd-4df0-8eb1-0daed3f09ee5/WFADevice.xml (0, No error) (Empty reply from server)
Feb 09, 2020 12:26:12.837 [0x7f9a1e3da700] ERROR - SSDP: Error parsing device schema for http://192.168.250.1:1990/0bf9a260-52cd-4df0-8eb1-0daed3f09ee5/WFADevice.xml
Feb 09, 2020 12:28:01.556 [0x7f99effff700] ERROR - Sync: could not get sync list 18784542, sync item 35624264 to update status
Feb 09, 2020 12:28:01.556 [0x7f99effff700] ERROR - Sync: could not get sync list 18784542, sync item 35624276 to update status
Feb 09, 2020 12:28:01.556 [0x7f99effff700] ERROR - Sync: could not get sync list 18784542, sync item 35624281 to update status
And it basically goes on from there.
Grateful for any suggestions at this point,
