Server Version#: 1.23.5.4862, on Debian Linux “Buster”.
Player Version#: Plex Web 4.61.2 and Plex android 8.20.1.26670 (caf51fef)
Tuner Make/Model: HDHomerun Flex 4K
Guide/Lineup name: Local Broadcast Listings (69 channels)
Using XMLTV?: No.
Channel number/Name: WTOO-CD , virtual channel 50, UHF Digital channel 22
My problem is that I can’t get any info on WTOO-CD from Plex’s buit-in EPG data. WTOO-CD is broadcast from a tower in Laurel Ridge state park in Cambria County, PA, and right next to it is a tower for WJAC-TV, which shows up without issue. I’d like for WTOO to be added to the EPG data.
Fortunately, it seems like they only broadcast channels that are available on other channels. So what I’ve done in the meantime is map those channels to other channels in the area that I can’t pick up. Titantv seems to indicate that the lineups seem to match. So I guess that’s a solution, even if it isn’t that good of a solution.
Still, I noticed that SchedulesDirect lacks that station too. I contacted them about it, and they said that they’d add it. Do you guys think you are better than SchedulesDirect and Jellyfin?
