This is getting annoying. Why does the team keep insisting on getting rid of the alphabetized list on the right of the screen when it is super useful. Update and it’s gone. Update and it’s there. What the hell is going on???
Which client type?
There is a known issue with some of the ‘big screen’ plex apps. This will be fixed with client updates.
In general, the letters will only show if there are “enough” items to display. Which means that if you apply a “filter”, so that the number of items goes below the threshold, the index letters may vanish.
The letters will also only show if you sort the library after ‘title’.
Duake Is absolutely right! We highly depend on alphabetized listing. Please correct this issue!
It’s missing on my Plex for Samsung (4.5.1) Tizen (2.4.0) client. Used to be there, now it’s not. 1,456 items sorted by Title so that’s not the issue.
