Hi
After the creator update I have some problem using the Xbox one remote control. Stop is no longer working, I have to press the back button to stop a movie from playing in plex.
Also the play/pause button it’s no longer functioning.
Hi
The Xbox might just need a reboot. I have the same problem almost every time Microsoft updates the Xbox OS. Try a cold reboot and hold down the power button on the console for 10 seconds if a regular reboot doesn’t work. Hopefully that works for you.
Ok, found out that if it doesnt work I only have to close the app and restart it.
