Hi, in the last few days i have noticed that i can no longer use the buttons for play/pause, rewind/forward etc in the plex app. i must use the navigation buttons to do these things, have something changed in the app or is my remote broken?
Hi
- Hard reboot your XBox console
- If it´s not solved by this put in a DVD or BluRay or use the Youtube app (basically anything) and try if the buttons work there to determine it it might really be broken.
1: hard reboot resolved, thx =)
Same here, Official Xbox Media remote wouldn’t work after upgrading to 1.0.0.2261. Hard reboot of the Xbox One solved it - many thanks.
