Strange collection behavior on v1.28.1.6104
Server Version#: 1.28.1.6104
I run Plex from a docker on my Unraid system. Yesterday I spent a couple of hours creating some movie collections with no problems. Last night, my appdata was backed up as per the schedule I have set (every Monday night, starting at 2am), and the backup processed with no issues.
Today, I try to make a collection, and it’s not working. The server is up, I can connect to it, new media is being added, I can play files locally and remotely, and I can even add movies to an existing collection - but I cannot create a new collection.
I’ve tried two methods: editing the “Tag” field in a movie and creating a collection there, and selecting multiple movies and using the “Add to Collection” button. The former method does nothing after I click “Save”; the latter method actually gives me an error: “Something went wrong. Make sure the server is available and try again.” These errors occur if I connect directly via IP, or via the plex.tv proxy method.
This is super confusing. Anyone know what possible explanation there might be for this behavior?
Can you post your server logs?
Can do:
Update: I was able to successfully create a new collection by using the Advanced Filters in my movie library, only showing (in this case) titles that contained “rush hour”, then saving that as a collection. Still weird that I can’t do this using the other two methods mentioned above.
