Your Synology is more than capable.
I do see an error in your logs where it had a filesystem fault trying to read the file.
I don’t see any “file system full” or other obvious errors.
Dec 08, 2019 21:05:06.335 [0x7fb4799e9700] DEBUG - Request: [127.0.0.1:52276 (Loopback)] PUT /video/:/transcode/session/4bb0b683-d4e7-47b9-b5f7-48969dd516fd-1/7e1437c2-a589-4fcb-a53b-c69fa191edf6/progress/stream?index=2&id=0&codec=ac3&type=audio (7 live) Signed-in Token (craiglichtenstein@gmail.com) (range: bytes=0-)
Dec 08, 2019 21:05:06.335 [0x7fb4b92df700] DEBUG - Completed: [127.0.0.1:52276] 200 PUT /video/:/transcode/session/4bb0b683-d4e7-47b9-b5f7-48969dd516fd-1/7e1437c2-a589-4fcb-a53b-c69fa191edf6/progress/stream?index=2&id=0&codec=ac3&type=audio (7 live) 0ms 195 bytes (pipelined: 8) (range: bytes=0-)
Dec 08, 2019 21:05:06.337 [0x7fb47bd11700] DEBUG - Request: [127.0.0.1:52276 (Loopback)] PUT /video/:/transcode/session/4bb0b683-d4e7-47b9-b5f7-48969dd516fd-1/7e1437c2-a589-4fcb-a53b-c69fa191edf6/progress/streamDetail?index=0&id=0&codec=mpeg2video&type=video&profile=Main&language=eng&width=720&height=480&interlaced=0&sar=32:27&level=8&frameRate=29.970 (7 live) Signed-in Token (craiglichtenstein@gmail.com) (range: bytes=0-)
Dec 08, 2019 21:05:06.338 [0x7fb4b92df700] DEBUG - Completed: [127.0.0.1:52276] 200 PUT /video/:/transcode/session/4bb0b683-d4e7-47b9-b5f7-48969dd516fd-1/7e1437c2-a589-4fcb-a53b-c69fa191edf6/progress/streamDetail?index=0&id=0&codec=mpeg2video&type=video&profile=Main&language=eng&width=720&height=480&interlaced=0&sar=32:27&level=8&frameRate=29.970 (7 live) 0ms 195 bytes (pipelined: 9) (range: bytes=0-)
Dec 08, 2019 21:05:06.338 [0x7fb4b95cd700] DEBUG - Request: [127.0.0.1:52276 (Loopback)] PUT /video/:/transcode/session/4bb0b683-d4e7-47b9-b5f7-48969dd516fd-1/7e1437c2-a589-4fcb-a53b-c69fa191edf6/progress/streamDetail?index=1&id=0&codec=ac3&type=audio&bitrate=192000&language=eng&channels=2&layout=stereo&sampleRate=48000&disp_default=1 (7 live) Signed-in Token (craiglichtenstein@gmail.com) (range: bytes=0-)
Dec 08, 2019 21:05:06.339 [0x7fb4b8ff1700] DEBUG - Completed: [127.0.0.1:52276] 200 PUT /video/:/transcode/session/4bb0b683-d4e7-47b9-b5f7-48969dd516fd-1/7e1437c2-a589-4fcb-a53b-c69fa191edf6/progress/streamDetail?index=1&id=0&codec=ac3&type=audio&bitrate=192000&language=eng&channels=2&layout=stereo&sampleRate=48000&disp_default=1 (7 live) 0ms 195 bytes (pipelined: 10) (range: bytes=0-)
Dec 08, 2019 21:05:06.339 [0x7fb4a8855700] DEBUG - Request: [127.0.0.1:52276 (Loopback)] PUT /video/:/transcode/session/4bb0b683-d4e7-47b9-b5f7-48969dd516fd-1/7e1437c2-a589-4fcb-a53b-c69fa191edf6/progress/streamDetail?index=2&id=0&codec=ac3&type=audio&bitrate=192000&language=eng&channels=2&layout=stereo&sampleRate=48000 (7 live) Signed-in Token (craiglichtenstein@gmail.com) (range: bytes=0-)
Dec 08, 2019 21:05:06.340 [0x7fb4b92df700] DEBUG - Completed: [127.0.0.1:52276] 200 PUT /video/:/transcode/session/4bb0b683-d4e7-47b9-b5f7-48969dd516fd-1/7e1437c2-a589-4fcb-a53b-c69fa191edf6/progress/streamDetail?index=2&id=0&codec=ac3&type=audio&bitrate=192000&language=eng&channels=2&layout=stereo&sampleRate=48000 (7 live) 0ms 195 bytes (pipelined: 11) (range: bytes=0-)
Dec 08, 2019 21:05:06.340 [0x7fb4a9fc5700] DEBUG - Request: [127.0.0.1:52276 (Loopback)] PUT /video/:/transcode/session/4bb0b683-d4e7-47b9-b5f7-48969dd516fd-1/7e1437c2-a589-4fcb-a53b-c69fa191edf6/progress/streamDetail?index=3&id=0&codec=dvd_subtitle&type=subtitle&language=eng&disp_default=1 (7 live) Signed-in Token (craiglichtenstein@gmail.com) (range: bytes=0-)
Dec 08, 2019 21:05:06.341 [0x7fb4b92df700] DEBUG - Completed: [127.0.0.1:52276] 200 PUT /video/:/transcode/session/4bb0b683-d4e7-47b9-b5f7-48969dd516fd-1/7e1437c2-a589-4fcb-a53b-c69fa191edf6/progress/streamDetail?index=3&id=0&codec=dvd_subtitle&type=subtitle&language=eng&disp_default=1 (7 live) 0ms 195 bytes (pipelined: 12) (range: bytes=0-)
Dec 08, 2019 21:05:06.341 [0x7fb4799e9700] DEBUG - Request: [127.0.0.1:52276 (Loopback)] PUT /video/:/transcode/session/4bb0b683-d4e7-47b9-b5f7-48969dd516fd-1/7e1437c2-a589-4fcb-a53b-c69fa191edf6/progress/streamDetail?index=4&id=0&codec=subrip&type=subtitle&language=eng (7 live) Signed-in Token (craiglichtenstein@gmail.com) (range: bytes=0-)
Dec 08, 2019 21:05:06.342 [0x7fb4b8ff1700] DEBUG - Completed: [127.0.0.1:52276] 200 PUT /video/:/transcode/session/4bb0b683-d4e7-47b9-b5f7-48969dd516fd-1/7e1437c2-a589-4fcb-a53b-c69fa191edf6/progress/streamDetail?index=4&id=0&codec=subrip&type=subtitle&language=eng (7 live) 0ms 195 bytes (pipelined: 13) (range: bytes=0-)
Dec 08, 2019 21:05:09.018 [0x7fb4a99e9700] DEBUG - Cleaning directory for session 4bb0b683-d4e7-47b9-b5f7-48969dd516fd-1 (/volume1/Plex/Library/Application Support/Plex Media Server/Cache/Transcode/Sessions/plex-transcode-4bb0b683-d4e7-47b9-b5f7-48969dd516fd-1-185c78c3-ea76-458b-8c85-2596481181ac)
Dec 08, 2019 21:05:09.458 [0x7fb4a8567700] ERROR - [Transcoder] [matroska,webm @ 0x24e6a80] Read error at pos. 614636160 (0x24a29a80)
Dec 08, 2019 21:05:16.213 [0x7fb4aa5a1700] DEBUG - Using default transcode duration of 120 minutes
Dec 08, 2019 21:05:16.213 [0x7fb4aa5a1700] DEBUG - Started session successfully: 4bb0b683-d4e7-47b9-b5f7-48969dd516fd-1
Dec 08, 2019 21:05:16.213 [0x7fb4aa5a1700] DEBUG - Waiting for 1 segment(s) before returning M3U8
Dec 08, 2019 21:05:16.644 [0x7fb4b92df700] DEBUG - Auth: authenticated user 1 as craiglichtenstein@gmail.com
At this level of logging, I do not know if that’s the source file or the transcoder temp file faulting or even an undiscovered quirk in PMS.
First, since it’s the easiest, update PMS to the newer beta release.
If it repeats, take the next step
I would next run comparative tests with other videos in PMS and against other players (VLC, etc). If they play fine then I would start to suspect the PMS. If they fail then I would suspeddt the file(s) or the NAS.
If all tests point to the Syno, although it will take time to do, I suggest running a scrub of the raid volume and verify its integrity.
If you wish, and to be more thorough,
- Check the event logs for any errors
- Restart DSM and give it a chance to clean up any file system glitches if they exist.
- These failing, and the problem persisting, definitely run the scrub.
