My Pi 2 with Rasplex 1.0.2 is stuck on “Downloading update 0%…” for weeks now. See attached picture.
I’ve tried rebooting it lots of times, disconnecting it from the network/internet, changing the update channel, turning auto check for updates, etc… nothing helps!
Is there a way around this? Can I do a manual update to 1.6.2 possibly? If so, how?!
Just reflash the SD card as if you are installing it for the first time.
http://www.rasplex.com/get-started/rasplex-installers.html
So wipe it and reinstall as new you mean?
I’d loose my configuration then… unless there is a way to export it?
Yes.
Yes, you’d lose your player configuration.
Sorry, no idea whether that is possible or not.
Yeah that’s what I was trying to avoid. Or find out how to export config, update manually or fix it!
Try switching to the pre-release channel.
Yeah I did, just sits there on downloading update 0%…
Is your time/date setup correctly? If not you could add an NTP server. Other than that, I’m guessing you’ll probably need to wipe and reflash as @Ottokerner suggested. You probably have another issue going on which most likely includes corruption.
Yes I have NTP server, why could date/time affect this?
Some encryption and API models require it. I don’t know explicitly if it won’t update because the time/date is off. I’ve never tried updating a box that couldn’t reach a NTP server.
Sounds like you’re SD image is corrupted then. I’d reflash with the new OpenPHT image so you have a good starting point.
