Stutter when using subs in combination with direct play/direct stream
Server Version#: Version 1.16.3.1402
Player Version#: 3.105.0
Hi, I think I ran into a weird issue: when I force my media to be transcoded I can use subtitles without problems. If I set the app to direct play / direct stream (which it does) the stream will start to stutter whenever subtitles are visible on screen. If there are parts with no subs the stream will run on just great…
The issues started longer than a month ago. I forgot about it as I had set my server to just transcode everything :sweat_smile:
I’ve got a Samsung UE49KU6400.
