Stuttering issues only in newly synced episodes
Server Version#: 1.32.2.7100-248a2daf0
5.60.2, Platform version 3 (client version) - this is the mentioned version inside the smart tv app
5.32.1 - this is the mentioned installed version when I look in the Samsung app-store.
Hi, I’m using Plex media server to connect between my computer and my Samsung smart TV (MU9000). I’ve been using it for years without any issues. In the last few days new synced episodes doesn’t work properly on my tv, there is a weird stuttering every 2 seconds. The funny thing is when I try to play existing episodes they work properly. What can be the issue?
I tried with different “new” and “old” files from different shows and they all behave the same, the “new” ones doesn’t work and the “old” ones work as usual.
Obviously I tried to close and open the app on both ends, re-scan the library and refreshed the metadata.
The Plex versions on both ends are up-to-date.
Any ideas? Thanks in advance :folded_hands:t2:
Bringing it up
