I can’t recall exactly when this started but its more at the point where I’m over it.
More frequently playing is buffered and stuttering but only on some media. I have 3 RasPlex devices and the same media has an issue on all 3.
I came across a similar post (https://forums.plex.tv/discussion/313165/direct-play-on-rasplex-causing-bufferring-and-stuttering#latest) and I tried their suggestion but its not resolved the problem.
Media info attached if that helps.
Media
Video Resolution SD
Duration 41:54
Bitrate 486 kbps
Width 704
Height 400
Aspect Ratio 1.78
Container MP4
Video Frame Rate 24p
Web Optimized Yes
Audio Profile lc
Video Profile high
Part
Duration 41:54
File The Secret Circle S01E04 Heather.mp4
Size 145.77 MB
Audio Profile lc
Container MP4
Indexes sd
Web Optimized Yes
Video Profile high
Codec H264
Bitrate 426 kbps
Bit Depth 8
Chroma Location left
Chroma Subsampling 4:2:0
Frame Rate 23.976 fps
Height 400
Level 4.1
Profile high
Ref Frames 7
Stream Identifier 2
Width 704
Codec AAC
Channels Stereo
Bitrate 60 kbps
Language English
Audio Channel Layout stereo
Profile lc
Sampling Rate 48000 Hz
Stream Identifier 1
