Hi there,
It’s pretty frustrating that there’s no place to submit a bug - only security bugs. I don’t want to write a forum post about this - it’s not a debate I want to start. It’s a bug report I want to submit.
Where do I unload such?
Since many of the people that can and will help are simple users and since the actual Plex people do not regularly respond the best and only way to submit a “bug” is to post about it here on the forums.
You may get the debate you fear and you may find that the “bug” is actually correct operation or you may find that Plex is aware of and is fixing the “bug” or you may have someone tell you of a simple fix/workaround/setting will make your Plex-perience good again.
But I can guarantee that if you do not post about the bug on the forums your voice will not be heard and no one will tell you of any proposed fix/workaround.
There is no requirement for you to reply to others who reply to your post. I’m sorry we do not have a public repo for that. Many folk just append [bug] to the beginning of the title of the topic if they think is just a bug.
