Cwluc
March 1, 2016, 12:41pm
1
AFAIK the best way to get subs to display in Plex is has the media and the sub the sane filename
Ex:
name.of.tv.episode.s01.e01.avi
name.of.tv.episode.s01.e01.srt
I even checked to make sure there wasn’t an issue with the subs and loaded it up in MPC-HC and all was well. So what gives?
atrus
March 1, 2016, 12:55pm
2
name.of.tv.episode.s01e01.avi (remove the dot between s01 and e01)
name.of.tv.episode.s01e01.en.srt (en tells Plex it is an english subtitle file)
If that does not work, please attach a subtitle file that does not work for you and I will test in my setup.
Cwluc
March 5, 2016, 6:43pm
3
I’ve been using Plex for years I wonder why some subs won’t load until you add a language. I just had gotten used to “unknown srt” when selecting the sub. Thank you.
atrus
March 9, 2016, 8:52pm
4
My guess is that the language tag was not the thing that solved this. I would say that the removal of the dot solved it
