let me clarify. the subtitles are working after adding them to the directory.
i can see them in any plex client. the problem is that they disappear after while
and i must refresh metadata ion order to restore them until the next time.
no
it a downloaded video files in their original format.
.1.he.srt
.2.he.srt
and so on …
plex ignores the number.
this format has been working for me for a long time.
im using the number to add a few subtitles for the move and language.
the problem of disappearing subtitles happens also for other files
that has no number. it happens also with opensusbtitles.org agent downloaded subtitles.
as i mentioned before plex DOES recognize the subtitle files.
the problem it losing them after a while.
As you have experienced, it doesn’t really ignore the number.
There is no documentation about this, and I haven’t heard about this so far. Maybe you remeber this from a different video player?
Also important: these files must be inside a ‘season’ folder.
Otherwise external subtitles don’t work.
Did you success getting rid of the problem? I have the exact same thing going on. Subs disapearing after a while. I have not even downloaded the subs m self they are provided by plex itself through the agent opensubtitles. I don’t think FordGuy61 understand the problem it mst be somehting else since you also mentioned having this with subs from the agent
