Subtitles not working on iPad/through plexweb interface
this topic has come up alot on the regular forums but never plexpass?
So I'm one of the poor bastards who is dealing with this issue.
My media server is a clean-installed osx Mountain Lion plex media server (and the versions are always up to date). My iPad is second generation and it simply won't play anything with subtitles. It has the issue of taking a long time to load and skipping whenever there is text to be displayed. Obviously it's something going wrong with transcoding while there are subtitles to be displayed. The same issue happens on the plex web interface, although i've never actually gotten anything to play at all that way (it's fine when you turn off subtitles on both ipad and web).
regular plex client works like a charm though, because i think that only streams and doesn't transcode?
Anyway, as a plexpass member i'd like to know if this is a known issue, and something that's being worked on?
thanks!
Daan
Do you have direct play checked in plexweb prefs? If so it wont use subs if it can direct play the video
What kind of file is it? What kind of subs?
this is an mkv with h264 video and embedded srt subs which works fine for me in plex/web
i heavily rely on subtitles for my tv shows and movies due to my deafness and i use it all the time on my plex for android/ios/web… i had no problems with enabling subtitles on all. you will need to make sure you have SRT file renmaed to be the exact same as filename (for example. thedarkknight.mp4, thedarkknight.srt) plex will recongize it as “unknown”, you will need to click on “circled i” (using ios or android) to enable captionings then the web version will have a drop down menu saying Subtitles: unknown, english and so on.
let me know if you have any issues with your media and subtitlings.
direct play is enabled.
for a file named thedarkknight.mkv, my subtitle file would be called thedarkknight.nl.srt. (NL because it’s dutch). Plex HT recognises the subtitle perfectly.
on the ipad it skips like a ##### whenever there are subtitles: i can see parts of video where there are none, and as soon as there’s dialogue it starts to skip to another part where there are none, etc etc.
on plexweb it simply won’t load.
reason i know it’s the subtitles: when i turn them off, it works perfectly. This happens on every file that has subtitles, all mkv’s. some have external .srt’s, some have embedded subtitles.
would it be possible to tell me how/where i can find log files that might demonstrate my problem?
http://wiki.plexapp.com/index.php/PlexNine_PMS_TipsTricks#Plex_Log_Files
you can also use something like mediainfo to take a look at the details of mkv file itself http://mediainfo.sourceforge.net/en
I also have mkv with separate subtitle files and those work fine too in plex/web. I dont have an ipad so cant check that. your mkv could be using the header compression thing that can screw things up
