Subtitles won’t download at father in law
Hello,
Ive added my father in law to my plex server. For some reason my father in law cant download subtitles, the searching returns zero results. When I do the exact procedure I do get search results. We’re both on android and on the same WiFi. If i download the subtitle my father in law also doesn’t see it.
Here is a clip i made to show the procedure:
My plex server is running on Ubuntu bionic with PMS 4.41.1. Video streaming works fine.
Does anyone have an idea how I can fix this ?
Thank you!
Johan
That part is correct. Subtitles found this way are only available to the user that did the search. These are temporary for that user. If you want them available to everyone, you’ll need to add them manually or activate the opensubtitle option on your server when adding content.
I don’t know why your father’s device gets 0 results. I’ll need to see the logs from the app after recreating the problem.
This feature requires a Plex Pass. Your account has currently no Plex Pass attached to it.
