Suggestions for renaming software
I use mp3tag for renmaing my mp3 files.  I love it because its very small and easy to use and uninstrusive.
Is there something similar for renaming video files?  I have some tv shows that need to be renamed.
I use ReNamer.  It's not automatic, but it's plenty powerful for renaming all files in a folder, and subfolders if needed.
http://www.den4b.com/?x=products&product=renamer
thanks.  Is there any added junkware bundled with it?
Not as far as I know, no.
Just another thought that came to mind, Sickbeard (I think), has naming functionality. The benefit it has over something like ReNamer is the Sickbeard will/can add the episode name to the filename.  Where ReNamer works better for quick jobs.
Filebot is excellent as well ( http://www.filebot.net/ )
that one looked good, but it seemed to be bundled with alot of stuff.....
U just have to make sure you do click accept when your prompted
Sent from my SAMSUNG-SGH-I747 using Tapatalk
also, filebot required me to install java.  when i was installing java, something went wrong, and it messed up.  I'll need to try again today.
I use Bulk Rename Utility (http://www.bulkrenameutility.co.uk) - no adware etc, very easy install and includes context menu support. I use it for renaming TV Shows episodes in bulk once they are ripped.
