I noticed that Music Choice channel wouldn’t play. Below is a few entries from the log
[2020-03-29 03:23:57.969] Client 0 tuner 0 video converter: [mpegts @ 103f8640] Could not find codec parameters for stream 0 (Video: h264 ([27][0][0][0] / 0x001B), none): unspecified size
Consider increasing the value for the ‘analyzeduration’ and ‘probesize’ options
[2020-03-29 03:23:57.969] Client 0 tuner 0 video converter: [mpegts @ 103f8640] Could not find codec parameters for stream 1 (Audio: ac3 ([129][0][0][0] / 0x0081), 0 channels, fltp): unspecified sample rate
[2020-03-29 03:23:57.969] Client 0 tuner 0 video converter: [mpegts @ 103f8640] Could not find codec parameters for stream 3 (Unknown: none (ETV1 / 0x31565445)): unknown codec
[2020-03-29 03:23:57.969] Client 0 tuner 0 video converter: [mpegts @ 103f8640] Could not find codec parameters for stream 4 (Unknown: none (ETV1 / 0x31565445)): unknown codec
[2020-03-29 03:23:57.969] Client 0 tuner 0 video converter: [mpegts @ 103f8640] Could not find codec parameters for stream 5 (Unknown: none ([192][0][0][0] / 0x00C0)): unknown codec
[2020-03-29 03:23:57.969] Client 0 tuner 0 video converter: [mpegts @ 103f8640] Could not find codec parameters for stream 6 (Video: h264 ([27][0][0][0] / 0x001B), none): unspecified size
[2020-03-29 03:23:57.969] Client 0 tuner 0 video converter: [mpegts @ 103f8640] Could not find codec parameters for stream 7 (Audio: ac3 ([129][0][0][0] / 0x0081), 0 channels): unspecified sample format
[2020-03-29 03:23:57.969] Client 0 tuner 0 video converter: [mpegts @ 103f8640] Could not find codec parameters for stream 8 (Audio: ac3 ([129][0][0][0] / 0x0081), 0 channels): unspecified sample format
[2020-03-29 03:23:57.969] Client 0 tuner 0 video converter: [mpegts @ 103f8640] Could not find codec parameters for stream 10 (Unknown: none (ETV1 / 0x31565445)): unknown codec
[2020-03-29 03:23:57.969] Client 0 tuner 0 video converter: [mpegts @ 103f8640] Could not find codec parameters for stream 11 (Unknown: none (ETV1 / 0x31565445)): unknown codec
[2020-03-29 03:23:57.969] Client 0 tuner 0 video converter: [mpegts @ 103f8640] Could not find codec parameters for stream 12 (Unknown: none ([192][0][0][0] / 0x00C0)): unknown codec
