Surveillance cameras and Plex integration
Do we have any device to show single or multiple CCTV cameras via the Plex?
It could be IP cameras or integration with DVRs (hikvision, xiongmaitech or other Chinese brands)
I have accomplished something similar by installing ‘tvheadend’ under Linux, and then adding IP streams to this as sources.
I think the TVHeadend plugin for Plex is from the unsupported appstore.
If you can do without live view, just have the images or videos saved in a plex library folder. IP cams can often save to SMB and FTP addresses or something like ispy can act as a DVR and also save them in a plex library. Plex will automatically make them available. I currently use ispy for motion triggered videos and it works great. A way for live view would really be a plus but this is a VERY solid DVR option.
