Sync issues in 1.4.3.3433?
Anyone else having Sync issues in 1.4.3.3433? I’m running my Plex on newest unraid. I’m running this on unraid (newest version) using a docker. (I have replicated the problem on 1.4.3.3433 plugin as well). When I try to sync files they return with an error “This media was unable to be analyzed”. Files seem to progress thru the transcode (I see them on the file system) but upon completing the transcode this pops up. I rolled back to 1.3.4.3285 and the problem went away. Anyone else having this issue?
I have the same issue! I have not rolled back because i was hoping a update would be released SOON to fix it but might just need to roll back!
I run Plex on Ubuntu 16.10 and I have the issue too. The Plex Server would just hang when trying to sync anything and the only way to get it running again is restarting the service.
But now I tryed disabling https pipelining and webhooks in the network section of the plex server settings (you have to show advanced settings) and it seems to work fine now.
Hope this helps you until a fix comes out.
Not sure this is the same issue. Nothing appears to hang on mine. On sync, I can see the server transcode. It appears once the transcode finishes it errors out trying to sync to device with the “This media was unable to be analyzed” message
Anyone else having this problem syncing with 3433? I tried again, bringing my docker forward. the pipeline setting had no effect. Sync almost always fails with the “This media was unable to be analyzed” message. I have seen it work twice, but all other attempts fail. Reverting back to previous version works perfectly.
Can anyone suggest the log file(s) location to look at to diagnose further?
I am having similar issues with sync tasks failing after transcoding completes on 3433. You can download your log files by going to Settings->Server->Help and clicking the Download Logs which pulls down a zip file of all your logs. I’m taking a peak at my logs now to see if I can spot where it is failing.
Just upgraded to 1.4.4.3495 and so far I’m not seeing this sync problem anymore. Fingers crossed that it is fixed.
