Sync not working
Hello. I have been having an issue for the past few weeks where I have been unable to sync anything to my mobile device. In the ‘downloads & Sync’ menu, it just says “not syncing” and all items are listed as “pending”. I have updated and uninstalled and restarted the app multiple times. I have also updated the web server. I have a lifetime plex pass. Everything worked fine a few weeks ago. Any advice?
Did you try deleting all the sync jobs and recreating them again?
Yes. I even deleted all offline content and tried to reload.
Ok, please hit refresh and then grab the log from the app.
Ok. How do I grab the log?
https://support.plex.tv/articles/201573117-android-android-tv-fire-tv-logs/
plex-log-brett10144@gmail.com.zip
Sent logs. Please confirm.
The link is protected. Can you PM me an unprotected link?
For some reason it only grands it as a .zip file
Yeah, the zip file is fine. I meant the link is protected. Set the option to allow anyone access with the link and just send me the link via a PM.
I’m trying but it doesn’t give me the option after sharing the log
Email the logs to yourself then save the attachment and re-attach that to your comment here.
Got the log you sent.
Ok. I wasn’t sure if that worked.
You are on a cellular connection. There is a setting to allow syncing on a cellular connection. You have this off.
I have tried syncing over WiFi via my local network and over my cellular network. Would you like a new log while using local network?
Yes. Not working over cellular is expected if you have that turned off.
I also see something else in your log. The app is having trouble connecting to your server using a secured connection. You can access and stream content under an insecure connection, but I’m not sure if sync will work that way. Switch to LAN and send me a new log. Could be this connection issue causing the problem.
I did PM you a new log after connecting to my local network
I have confirmed that I am now connected to a secure server.
