Syncing of files > 3GB fails
When I try to sync files with an original size bigger than (around) 3 GB the conversion fails at 25-35% with message ‘The transcoder was unable to process this media’.
Tried to convert to 4Mbit / 720p or less. Files smaller than 3 GB are working well, streaming also. It doesn’t matter if the original files are local or on the NAS. Syncing with ‘Original quality’ is also working.
This is already for a couple of weeks, waited for the next release but Version 1.13.2.5149 has still the same behaviour.
I am having the exact same problem. I have tried several files and it fails everytime. When I check the logs, I get this error:
Jun 09, 2018 06:42:34.733 [22269] DEBUG - Jobs: ‘/data/user/0/com.plexapp.mediaserver.smb/Resources/Plex Transcoder’ exit code for process 11628 is -9 (signal: Killed)
Jun 09, 2018 06:42:34.759 [11627] ERROR - BIF transcoder exited abnormally
Jun 09, 2018 06:42:34.931 [22269] DEBUG - Jobs: ‘/data/user/0/com.plexapp.mediaserver.smb/Resources/Plex Transcoder’ exit code for process 12537 is -9 (signal: Killed)
Jun 09, 2018 06:42:34.942 [22263] DEBUG - Auth: authenticated user 1 as straasha
Jun 09, 2018 06:42:34.942 [11629] DEBUG - Request: [192.168.0.94:51073 (Subnet)] GET /status/sessions/background (10 live) TLS GZIP Signed-in Token (straasha)
Jun 09, 2018 06:42:34.944 [22263] DEBUG - Completed: [192.168.0.94:51073] 200 GET /status/sessions/background (9 live) TLS GZIP 2ms 734 bytes (pipelined: 1)
Jun 09, 2018 06:42:34.963 [12520] DEBUG - Streaming Resource: Changing client to use software decoding
Jun 09, 2018 06:42:34.963 [12520] ERROR - Streaming Resource: Cannot redecide static session
Jun 09, 2018 06:42:34.963 [12520] DEBUG - Streaming Resource: Terminating session 0x203d0a02a0:b395bf5a-637a-4794-8539-6389ff7724df which is using static transcoder slot. Used slots is now 0
Jun 09, 2018 06:42:34.971 [12534] DEBUG - Transcoder: Cleaning old transcode directories.
Jun 09, 2018 06:42:34.998 [12520] DEBUG - Streaming Resource: Terminated session 0x203d0a02a0:b395bf5a-637a-4794-8539-6389ff7724df with reason Neither direct play nor conversion is available.
Jun 09, 2018 06:42:34.998 [12539] DEBUG - Killing job.
Jun 09, 2018 06:42:34.998 [12539] DEBUG - Signalling job ID 12537 with 9
Jun 09, 2018 06:42:34.998 [12539] DEBUG - Job was already killed, not killing again.
Jun 09, 2018 06:42:34.998 [12539] DEBUG - Stopping transcode session b395bf5a-637a-4794-8539-6389ff7724df
Jun 09, 2018 06:42:35.046 [12534] DEBUG - Transcoder: Cleaning old transcode directory: /storage/emulated/0/Plex Media Server/Transcode/Transcode/Sessions/plex-transcode-b395bf5a-637a-4794-8539-6389ff7724df-8e727a01-4168-4fbc-b1fa-0515a459ac02
Jun 09, 2018 06:42:35.067 [12534] DEBUG - Whacked session b395bf5a-637a-4794-8539-6389ff7724df, 0 remaining.
Jun 09, 2018 06:42:35.067 [12534] DEBUG - TranscodeJobManager: transcode of metadata item 62 failed with exit code -9
Jun 09, 2018 06:42:35.098 [12534] DEBUG - TranscodeJobManager: [Running] job b395bf5a-637a-4794-8539-6389ff7724df complete - failure / transcoderError
Jun 09, 2018 06:42:35.098 [13210] DEBUG - BPQ: onAsynchronousJobComplete
Jun 09, 2018 06:42:35.098 [13210] DEBUG - BPQ: completing transcode for sync metadata item 62: failure / transcoderError
Jun 09, 2018 06:42:35.148 [12539] DEBUG - Transcoder: Cleaning old transcode directories.
Jun 09, 2018 06:42:35.167 [12539] DEBUG - Whacked session b395bf5a-637a-4794-8539-6389ff7724df, 0 remaining.
Jun 09, 2018 06:42:35.909 [13210] DEBUG - Sync: processed item 62 for sync list 14694792, sync item 27798610: failure/transcoderError
Jun 09, 2018 06:42:35.909 [13210] DEBUG - BPQ: generator 19 changed state: pending -> complete
Jun 09, 2018 06:42:35.910 [13210] DEBUG - Sync: sync list 14694792, sync item 27798610 changed state from pending to complete
Jun 09, 2018 06:42:35.910 [13210] DEBUG - Sync: sync list 14694792, sync item 27798610: complete/good with 1/0/1/0/0/0 item(s)
Jun 09, 2018 06:42:35.911 [13210] WARN - [Analytics] Attempting to send unrecognized metric (sync:processed). Skipping.
I am using PMS 1.13.2.5149. This error occurred with both Nvidia Shield 6.3 and 7.0.1. I have a 64 GB USB drive formatted as internal media and have the PMS data move to it so space is not the issue.
Try to turn off the hardware acceleration in transcoder section.
I know. But this is a workaround, not a solution. Without HW transcoding, everything is extremely slow.
I am having the same issue as described and I don’t think turning off hw acceleration is a good solution. What is the fix for this? I have bought a plex pass mainly to sync media to my devices and hate that it’s not working.
The same here
Updated the server to Plex Media Server 1.13.5.5291 and we continue the same … Is there anyone working on this? The conversion with the acceleration off is sloooow
PMS 1.13.7.5369 solved this now for me.
Thank you
