Synology - DSM 7 Release 7.0.1-42214 - Plex Installation Issues - DS415+
Server Version#: 1.24.2.4973-2b1b51db9-armv7neon_DSM7
Unable to get past the “This package is not supported on the platform of DiskStation or is incompatible with the current DSM version.” message.
Apologies if this was covered, but I was not able to find it easily in the search. There are lots of mentions for the previous DSM 7 version.
I did follow the guidelines from @ChuckPa in migrating from DSM 6.2 to DSM 7, but I just get stuck at the manual installation step. I remember long ago having to update the package manually to allow newer versions of DSM. Is that possible?
Any advice or help would be appreciated and Thank You
@trumpy81, I must have been tired as it was 0200. I thought I had tried them all especially that one first. It is not like this was my first time installing and I thought I was being good by selecting the one for my series. Oh Well. Live and learn.
Thank You for responding!
