So over the past several months I have been scouring the web for an easy and affordable option so play the same music at two locations that “sync up” correctly. Sonos does it and I have an old Sonos Connect player in my main living/theater room but I just don’t have the money to shell out for another player for my MB so I started looking for alternatives. First thing I found was the Google Music Cast device, Perfect I thought!.. oh wait they discontinued it! OK, no problem, I find a few pages that talk about connecting the Google Nest Mini (Gen-2) via Bluetooth to external BT speakers, Great!, I have a BT enable Logitech Z537 speakers in my bedroom that are connected to my laptop and I find a lot of web pages talking about how the Shield TV can now be “Grouped” into the “Create speaker group” option in the Google Home app… Sweet! I found an affordable solution for sending music to both my systems at the same time (or so I thought)… So I find a killer discount deal on the Nest Mini ($39) close to what a Google Audio cast used to cost and I start setting up my cheap Sonos alternative… I get the Mini all setup and start sending my PlexAmp music to it, Great it works!, I then go to add the Shield TV to the mix… strange, it does not show up under the “Create speaker group”??? Ok, I do a little more digging online and and says you need to be on the Beta of the Chromecast built-in so that you have version 1.47, Ok, no problem. I join the Beta group and reinstall Chromecast on the Shield TV… still nothing… Ok, let me chat with Google and see if they can help me… see where this is going yet???.. so I chat with Google Nest support, they have me try everything that I already tried, reboot everything, uninstall and reinstall the Google Home app… stand on one leg with my right index finger touching the tip of my nose… well you get the idea… then they tell me, we will need to investigate this issue more and will call you back in 1-2 hours… OK, great! Google should be able to figure this out … right?
So I wait and wait… no call… but then 4 hours later and email shows up… here is what they tell me:
"Hello Mark,
Thanks for reaching out to the Google Nest Customer Care Team.
This is Jacqueline, one of Maurine Joy’s colleagues. I apologize for the late call back and I tried to reach out on you but it seemed like call keeps on disconnecting.
In regards to your previous concern in creating a speaker group/ multi-room group on the Google Home app with your Google Home Mini and Nvidia Shield TV, after further investigation we have verified that Home Group integration for Built-in Chromecast and Android TV has been removed and it’s no longer supported.
Nvidia Shield TV is powered by Android TV with Chromecast built-in and it’s integration for the Home group feature has been removed together with Chromecast built-in TV due to complex error with the integration. This is also the reason why you are unable to see the Shield TV when attempting to create a group.
For your reference your case number is 2-5993########6. If you need more help, you can contact us again and reference this case number or reply to this email to reopen your case.
Have a new question? There are lots of ways to get back in touch with us below.
Thank you,
Jacqueline
The Google Nest Customer Care Team"
So now I am not a very happy Google customer. So it looks like there is currently only one expensive solution available and that is Sonos? I really find that amazing.
I really hope Plex can step up and fill the void of a much needed “Whole Home Audio Solution.”
