Finally back from my trip to India and can access my system again. I’ve tried restarting applications a few times and still don’t see anything in the recently added on the homepage. It searches for it:
That solved it. I had the home page items on Plex turned off because wifey doesn’t like how cluttered it makes the page when you open Plex. So it won’t work for me on Tautulli.
We’ve seen this question asked a few times in the past - would it be difficult to show recently added in Tautulli even if Plex has the dashboard hidden?
I imagine this being a wanted feature - Plex does get cluttered, where as you have made a nice UI.
If overly difficult to make it happen (due to Plex API), perhaps a mention of it needs to be placed in the FAQ.
Q: “Why are my Recently added not showing, even though logs indicate new items, as does Plex?”
A: “You must have recently added hubs in Plex listed for the libraries you want monitored”
(To be honest, I’m not even sure how to hide the hubs - but, I’m sure it’s in the Support articles somewhere)
I would have to check every library and combine them into one list and sort them in the correct order. That’s a lot of API calls rather than just one API call for recently added.
When I select one of these libraries in Tautulli and then select “Media Info” the “Fetching Rows” popup remains without any results being displayed. The other options within Libraries, Profile and History, work fine.
Looking at the Tautulli Logs an error occurs but I do not understand the error message :
Can anyone interpret this error for me and give me advice on how to resolve the issue. As this works for 3 of my libraries I presume I have some items in these3 libraries that is upsetting Tautulli.
Why do half the notifications from Tautulli come up with Tautulli in the text, and half say “PlexPy”? Its been happening for months, even after many updates to the software.
How do I update Tautulli? Every time I try in the GUI there is never an update. The version on GitHub is newer then what I have (2.1.14 is current, I have 2.0.22). I don’t see anything in the FAQ the specifically says how to do it if you’re just upgrading normally.
Edit: Figured it out. Open Terminal, navigate to Tautulli folder (in my case “cd /Applications/PlexPy”) then “git pull origin master”.
