Server Version#: 1.27.0.5897
Player Version#: ?? Roku
TV Model 65R615
Supports DV (not sure which profiles)
Expectation : DV plays correctly. failing that downgrades gracefully to HDR, or in the worst case SDR giving proper colors.
Behavior : A tv episode with the following metadata plays green/purple. (but see below for a second file which DOES play correctly)
- Codec HEVC
- Bitrate 14016 kbps
- D O V I B L Present true
- D O V I Level 6
- D O V I Present true
- D O V I Profile 5
- D O V I R P U Present true
- D O V I Version 1.0
- Bit Depth 10
- Chroma Location left
- Chroma Subsampling 4:2:0
- Coded Height 2160
- Coded Width 3840
- Color Range pc
- Frame Rate 23.976 fps
- Height 2160
- Level 5.0
- Profile main 10
- Ref Frames 1
- Width 3840
- Display Title 4K DoVi (HEVC Main 10)
- Extended Display Title 4K DoVi (HEVC Main 10)
However, the following file DOES play correctly
- Codec HEVC
- Bitrate 24451 kbps
- D O V I Level 6
- D O V I Profile 5
- Bit Depth 10
- Codec ID dvhe
- Coded Height 1600
- Coded Width 3832
- Color Range tv
- Height 1596
- Level 5.0
- Profile main 10
- Ref Frames 1
- Stream Identifier 1
- Width 3832
