"The Guide is empty" in Australia after setup with HDHomeRun and IceTV (PMS 1.18.3.2111 64-bit Ubuntu)
I can watch channels on my HDHomeRun CONNECT Duo using the HDHomeRun app successfully.
However when setting up the Live TV & DVR on my PMS, I was unable to progress past the language select screen. After reading the following forum threads:
https://forums.plex.tv/t/cant-progress-past-select-language-screen-in-dvr-setup/202248
https://forums.plex.tv/t/dvr-setup-in-australia-not-working/423346
I thought the solution would be to use IceTV’s EPG service. I signed up to their free trial and set up the EPG using the guide provided by IceTV.
The guide has finished downloading, but when I go to the guide tab, it says “The Guide is empty”.
My logs are provided and any help would be greatly appreciated!
Plex Media Server Logs_2019-12-05_13-34-17.zip (147.9 KB)
Update #1
I was reading through the logs and noticed the timestamps were incorrect. I hadn’t set a timezone on my OS so the EPG didn’t have any entries since I’m GMT+11.
I can now see the guide but cannot load the channels.
Update #2
I restarted the VM running PMS and it is working now but buffering, but that appears to be a hardware problem for me. Hopefully there will not be a third update!
