The Right Stuff 2020 mismatch
Server Version#:1.24.0.1483-714cba36
I am having trouble matching the new The Right Stuff (2020) from Disney. It always matches to a 2019 series. I have named the folder “The Right Stuff (2020)”. Season 01 and then the 8 episodes. I have looked for bad metadata in properties and found none.
Any suggestions will be appreciated.
Thanks,
Fix Match, select “The Right Stuff” dated 2020 from The TVDB agent.
I do not have a “Fix Match” option on the TV Library.
Thanks,
You should find it at the series level.
I finally found it.
Thank you.
