The server does not allow secure connections
Server Version#:1.16.5.1552-8e8d0c785
Changed router but everything else connected works (eg back server/printers etc)
now get this error
I can access the server files via windows explorer but I cant access plex via
the web or any other plex app.
Any ideas and it is set to secure connection preferred.
Thank you in advance for your help
If you can’t use secure connections in the LAN, it is in 95% of cases caused by DNS.
Hi
changed the DNS to 8.8.8.8 and still have the same issue.
Still cant connect to it.
I have access to the server via windows and I can see my files etc
but plex just cant connect to it
Then it is DNS rebinding protection, which might be active in your DNS resolver (usually the router or the firewall). Sometimes also in the web browser. Try another one.
I looked everywhere and cant find a way to turn of DNS rebinding protection.
Currently running a
D-Link Cobra Router
set the dns to 8.8.8.8
and still no luck
Then I’m afraid you need to look for an alternative firmware for this device (which of course leads to loss of warranty and support). Think Tomato, dd-wrt, open-wrt etc.pp.
I worked it out and it was not the router issue but Synology NAS issue not having the dns settings as you sugguested
Synology NAS
here is what i did to fix the issue on the Synology NAS
Go to Control Panel > Network > General and tick the Manually configure DNS server checkbox, and then set the DNS server value to “8.8.8.8” or “8.8.4.4”.
Now it works so suggest if people have a issue to change router to googles DNS and also the NAS system they are running.
Thank you to OttoKerner for pointing me in the right direction.
