TheTVDB Agent not auto matching shows released in 2020
My naming convention is the same as yours, with the only difference being I specify the year in the TV Show title ie.
/tv/The Pale Horse (2020)/Season 01/The Pale Horse (2020) - S01E01.mkv
The naming convention as far as I can tell is fine, as all shows released in 2019 or earlier match fine, and even the 2020 shows match with 100 accuracy when I select “match”
… and as we’ve found through rigorous, painful testing - by filthy, smelly Plex Veteran Volunteer Data-Moles (lol)… that action will bork a match faster than you can say Jack Robinson:
The trick to this matching thing - use the exact name they use - like Filebot does. If a (YEAR) field is in the official name, use it. Otherwise, don’t.
Problem solved. I haven’t had a mismatch, or a ‘no match’ in weeks.
BTW:
MP4 Files?
Lower Local Media Assets to the bottom of the stack of active agents under all tabs in Shows and Movies (Server/Settings/Agents).
When changing names - if it doesn’t work - Plex Dance it:
unfortunately, the advise to always put the (year) in the series, has been causing issues since tvdb changed the api.
this currently seems to be the best advice.
but I keep the (year) in my series titles anyway, and if I have to fix match, then I fix match.
As it should be - you are the Control (Stubborn) Group.
lol
plex shall bend to my will! /arrrrr
Unfortunately, as we’re finding out, if you don’t use a pristine name for the natural match, you may not have a show in the fix match list to select.
That’ll scorch your 'maters.
I know how to change the search string and/or remove the year or special characters.
If that does not work, then I am a patient man.
I’m not having an issue with matching, when I press “Match” it instantly finds a result with a score of 100. So my naming convention can’t be an issue?
The issue is Plex doesn’t match 2020 shows when adding them to the Library via the Library Scan process.
If my naming convention was an issue, Plex wouldn’t find a 100 result when selecting “Match”
Dunno - let’s see it, so I can test it.
I posted my naming convention earlier.
It’s the same as yours, but has the year in the TV Show name.
Right, sorry.
Well, as we have discovered if you put a (YEAR) Field in a Show that doesn’t require it - it fails 100% of the time.
Now, you tell me: What’s the name of this show?
What’s the name of this one?:
I get what you are saying- you’re not really answering my question though.
Your response would apply if I wasn’t getting any result when selecting “Match”. But I am. I’m getting a 100 response with The Pale Horse (2020).
So my question is:
If I am getting a 100 match on a file, why isn’t Plex applying this match when running a library scan?
We’re just gathering the data for this thread:
Our discoveries are fed to Plex through our ‘Liaison’. What Plex does or doesn’t do with that info is beyond my control and ‘why’ something doesn’t work doesn’t concern me as much as finding what does work.
I set Filebot to use the EXACT NAME TVDB uses.
So far it’s working 100% of the time. Like the old days.
I couldn’t be happier (well, I could, but…).
If my file name gets a natural match 100% of the time - worrying about what happens in a Fix Match would be insane. All I want to do is Use Plex. I know how. And now, so do you.
The reason I don’t accept your diagnosis is that Plex will auto match TV Shows with Year in the title, as long as they aren’t from 2020.
For example, I just added The King of Queens (1998) and it matched during the library scan.
TheTVDB references this show as “The King of Queens”. No year in the title.
Yet Plex matched it during the Library scan.
If I may augment here again?
Supplying the year isn’t required, and is sometimes detrimental, if it’s the first time the series name has been used.
In the case of “Cobra” , I did not list the year.
Making "Cobra/Season 01"
Making "Cobra/Season 02"
Making "Cobra/Season 03"
Making "Cobra/Season 04"
Done
[chuck@lizum ~.502]$ ls -la /vie/qa/tv/Cobra
total 64
drwxr-xr-x   6 chuck chuck  4096 Feb 28 23:52 ./
drwxr-xr-x 917 chuck chuck 45056 Feb 28 23:52 ../
drwxr-xr-x   2 chuck chuck  4096 Feb 28 23:52 Season 01/
drwxr-xr-x   2 chuck chuck  4096 Feb 28 23:52 Season 02/
drwxr-xr-x   2 chuck chuck  4096 Feb 28 23:52 Season 03/
drwxr-xr-x   2 chuck chuck  4096 Feb 28 23:52 Season 04/
[chuck@lizum ~.503]$ ls -la /vie/qa/tv/Cobra/*01
total 88
drwxr-xr-x 2 chuck chuck 4096 Feb 28 23:52 ./
drwxr-xr-x 6 chuck chuck 4096 Feb 28 23:52 ../
-rw-r--r-- 1 chuck chuck  258 Feb 28 23:52 Cobra - S01E01.mkv
-rw-r--r-- 1 chuck chuck  258 Feb 28 23:52 Cobra - S01E02.mkv
-rw-r--r-- 1 chuck chuck  258 Feb 28 23:52 Cobra - S01E03.mkv
-rw-r--r-- 1 chuck chuck  258 Feb 28 23:52 Cobra - S01E04.mkv
-rw-r--r-- 1 chuck chuck  258 Feb 28 23:52 Cobra - S01E05.mkv
-rw-r--r-- 1 chuck chuck  258 Feb 28 23:52 Cobra - S01E06.mkv
-rw-r--r-- 1 chuck chuck  258 Feb 28 23:52 Cobra - S01E07.mkv
-rw-r--r-- 1 chuck chuck  258 Feb 28 23:52 Cobra - S01E08.mkv
-rw-r--r-- 1 chuck chuck  258 Feb 28 23:52 Cobra - S01E09.mkv
-rw-r--r-- 1 chuck chuck  258 Feb 28 23:52 Cobra - S01E10.mkv
-rw-r--r-- 1 chuck chuck  258 Feb 28 23:52 Cobra - S01E11.mkv
-rw-r--r-- 1 chuck chuck  258 Feb 28 23:52 Cobra - S01E12.mkv
-rw-r--r-- 1 chuck chuck  258 Feb 28 23:52 Cobra - S01E13.mkv
-rw-r--r-- 1 chuck chuck  258 Feb 28 23:52 Cobra - S01E14.mkv
-rw-r--r-- 1 chuck chuck  258 Feb 28 23:52 Cobra - S01E15.mkv
-rw-r--r-- 1 chuck chuck  258 Feb 28 23:52 Cobra - S01E16.mkv
-rw-r--r-- 1 chuck chuck  258 Feb 28 23:52 Cobra - S01E17.mkv
-rw-r--r-- 1 chuck chuck  258 Feb 28 23:52 Cobra - S01E18.mkv
-rw-r--r-- 1 chuck chuck  258 Feb 28 23:52 Cobra - S01E19.mkv
-rw-r--r-- 1 chuck chuck  258 Feb 28 23:52 Cobra - S01E20.mkv
[chuck@lizum ~.504]$
It took less than 1 minute for autodetect to kick in and scan it.
On my slow internet, it took about 2 more minutes for it to complete.
Notice this is the 1993 name. This is correct behavior.
I now create “Cobra (2020)” and it jumps right in.
[chuck@lizum ~.505]$ ls -la /vie/qa/tv/Cobra*/*01
/vie/qa/tv/Cobra (2020)/Season 01:
total 88
drwxr-xr-x 2 chuck chuck 4096 Feb 28 23:58 ./
drwxr-xr-x 6 chuck chuck 4096 Feb 28 23:58 ../
-rw-r--r-- 1 chuck chuck  272 Feb 28 23:58 Cobra (2020) - S01E01.mkv
-rw-r--r-- 1 chuck chuck  272 Feb 28 23:58 Cobra (2020) - S01E02.mkv
-rw-r--r-- 1 chuck chuck  272 Feb 28 23:58 Cobra (2020) - S01E03.mkv
-rw-r--r-- 1 chuck chuck  272 Feb 28 23:58 Cobra (2020) - S01E04.mkv
-rw-r--r-- 1 chuck chuck  272 Feb 28 23:58 Cobra (2020) - S01E05.mkv
-rw-r--r-- 1 chuck chuck  272 Feb 28 23:58 Cobra (2020) - S01E06.mkv
-rw-r--r-- 1 chuck chuck  272 Feb 28 23:58 Cobra (2020) - S01E07.mkv
-rw-r--r-- 1 chuck chuck  272 Feb 28 23:58 Cobra (2020) - S01E08.mkv
-rw-r--r-- 1 chuck chuck  272 Feb 28 23:58 Cobra (2020) - S01E09.mkv
-rw-r--r-- 1 chuck chuck  272 Feb 28 23:58 Cobra (2020) - S01E10.mkv
-rw-r--r-- 1 chuck chuck  272 Feb 28 23:58 Cobra (2020) - S01E11.mkv
-rw-r--r-- 1 chuck chuck  272 Feb 28 23:58 Cobra (2020) - S01E12.mkv
-rw-r--r-- 1 chuck chuck  272 Feb 28 23:58 Cobra (2020) - S01E13.mkv
-rw-r--r-- 1 chuck chuck  272 Feb 28 23:58 Cobra (2020) - S01E14.mkv
-rw-r--r-- 1 chuck chuck  272 Feb 28 23:58 Cobra (2020) - S01E15.mkv
-rw-r--r-- 1 chuck chuck  272 Feb 28 23:58 Cobra (2020) - S01E16.mkv
-rw-r--r-- 1 chuck chuck  272 Feb 28 23:58 Cobra (2020) - S01E17.mkv
-rw-r--r-- 1 chuck chuck  272 Feb 28 23:58 Cobra (2020) - S01E18.mkv
-rw-r--r-- 1 chuck chuck  272 Feb 28 23:58 Cobra (2020) - S01E19.mkv
-rw-r--r-- 1 chuck chuck  272 Feb 28 23:58 Cobra (2020) - S01E20.mkv
The above example you showed highlights why the year in the title is crucial. Otherwise shows will match incorrectly.
The only time I have a match issue (where Plex won’t auto match during library scan) is when the year in the title is (2020).
Your example (I presume) involved you changing the title of the name in the “Match” functionality- which works every time for me also.
The issue I am experiencing is when you add a show with (2020) in the directory title, run a library scan (don’t press Match) - and Plex won’t auto match it as a part of the library scan process.
But a show released in 2019, with (2019) in the directory name, will auto match during library scan.
The only time TheTVDB puts the year in the title is when the series name is a remake / reuse.
What is your Agent stacking order?
