thetvdb API is broken (maybe TheTVDB scanner/helper won't work?)
As of a few minutes ago, I have verified that thetvdb API does not work. I go to the following website, api.thetvdb.com/swagger, and test out my (valid) authentication credentials, which I have kept blurred.
I find the following response, which seems to be cloudflare based and discouraging, a 522 error saying that the connection timed out.
<!DOCTYPE html>
<!--[if lt IE 7]> <html class="no-js ie6 oldie" lang="en-US"> <![endif]-->
<!--[if IE 7]>    <html class="no-js ie7 oldie" lang="en-US"> <![endif]-->
<!--[if IE 8]>    <html class="no-js ie8 oldie" lang="en-US"> <![endif]-->
<!--[if gt IE 8]><!--> <html class="no-js" lang="en-US"> <!--<![endif]-->
<head>
<meta http-equiv="set-cookie" content="cf_use_ob=0; expires=Mon, 06-Mar-17 19:59:53 GMT; path=/">
<title>api.thetvdb.com | 522: Connection timed out</title>
<meta charset="UTF-8" />
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
<meta http-equiv="X-UA-Compatible" content="IE=Edge,chrome=1" />
<meta name="robots" content="noindex, nofollow" />
<meta name="viewport" content="width=device-width,initial-scale=1,maximum-scale=1" />
<script type="text/javascript">
//<![CDATA[
try{if (!window.CloudFlare) {var CloudFlare=[{verbose:0,p:0,byc:0,owlid:"cf",bag2:1,mirage2:0,oracle:0,paths:{cloudflare:"/cdn-cgi/nexp/dok3v=1613a3a185/"},atok:"bb499d9f53320f90dde6850ce579ef66",petok:"07bdb2f3ad472220de800571fefe7a691935669e-1488830363-1800",zone:"thetvdb.com",rocket:"0",apps:{"ga_key":{"ua":"UA-9131861-1","ga_bs":"2"}}}];!function(a,b){a=document.createElement("script"),b=document.getElementsByTagName("script")[0],a.async=!0,a.src="//ajax.cloudflare.com/cdn-cgi/nexp/dok3v=f2befc48d1/cloudflare.min.js",b.parentNode.insertBefore(a,b)}()}}catch(e){};
</script>
<link rel="stylesheet" id="cf_styles-css" href="/cdn-cgi/styles/cf.errors.css" type="text/css" media="screen,projection" />
<!--[if lt IE 9]><link rel="stylesheet" id='cf_styles-ie-css' href="/cdn-cgi/styles/cf.errors.ie.css" type="text/css" media="screen,projection" /><![endif]-->
<style type="text/css">body{margin:0;padding:0}</style>
<!--[if lte IE 9]><script type="text/javascript" src="/cdn-cgi/scripts/jquery.min.js"></script><![endif]-->
<!--[if gte IE 10]><!--><script type="text/javascript" src="/cdn-cgi/scripts/zepto.min.js"></script><!--<![endif]-->
<script type="text/javascript" src="/cdn-cgi/scripts/cf.common.js"></script>
/* <![CDATA[ */
var _gaq = _gaq || [];
_gaq.push(['_setAccount', 'UA-9131861-1']);
_gaq.push(['_trackPageview']);
(function() {
var ga = document.createElement('script'); ga.type = 'text/javascript'; ga.async = true;
ga.src = ('https:' == document.location.protocol ? 'https://ssl' : 'http://www') + '.google-analytics.com/ga.js';
var s = document.getElementsByTagName('script')[0]; s.parentNode.insertBefore(ga, s);
(function(b){(function(a){"__CF"in b&&"DJS"in b.__CF?b.__CF.DJS.push(a):"addEventListener"in b?b.addEventListener("load",a,!1):b.attachEvent("onload",a)})(function(){"FB"in b&&"Event"in FB&&"subscribe"in FB.Event&&(FB.Event.subscribe("edge.create",function(a){_gaq.push(["_trackSocial","facebook","like",a])}),FB.Event.subscribe("edge.remove",function(a){_gaq.push(["_trackSocial","facebook","unlike",a])}),FB.Event.subscribe("message.send",function(a){_gaq.push(["_trackSocial","facebook","send",a])}));"twttr"in b&&"events"in twttr&&"bind"in twttr.events&&twttr.events.bind("tweet",function(a){if(a){var b;if(a.target&&a.target.nodeName=="IFRAME")a:{if(a=a.target.src){a=a.split("#")[0].match(/[^?=&]+=([^&]*)?/g);b=0;for(var c;c=a**;++b)if(c.indexOf("url")===0){b=unescape(c.split("=")[1]);break a}}b=void 0}_gaq.push(["_trackSocial","twitter","tweet",b])}})})})(window);
</script>
</head>
<body>
<div id="cf-wrapper">
    <div id="cf-error-details" class="cf-error-details-wrapper">
        <div class="cf-wrapper cf-error-overview">
            <h1>
              <span class="cf-error-type" data-translate="error">Error</span>
              <span class="cf-error-code">522</span>
              <small class="heading-ray-id">Ray ID: 33b7e4718b9b5128 &bull; 2017-03-06 19:59:23 UTC</small>
            </h1>
            <h2 class="cf-subheadline" data-translate="error_desc">Connection timed out</h2>
        </div><!-- /.error-overview -->
        <div class="cf-section cf-highlight cf-status-display">
            <div class="cf-wrapper">
                <div class="cf-columns cols-3">
<div id="cf-browser-status" class="cf-column cf-status-item cf-browser-status ">
  <div class="cf-icon-error-container">
    <i class="cf-icon cf-icon-browser"></i>
    <i class="cf-icon-status cf-icon-ok"></i>
  </div>
  <span class="cf-status-desc" data-translate="browser_desc">You</span>
  <h3 class="cf-status-name" data-translate="browser_label">Browser</h3>
  <span class="cf-status-label" data-translate="browser_status_label">Working</span>
</div>
<div id="cf-cloudflare-status" class="cf-column cf-status-item cf-cloudflare-status ">
    <i class="cf-icon cf-icon-cloud"></i>
  </div>
  <span class="cf-status-desc" data-translate="cloud_desc">San Jose</span>
  <h3 class="cf-status-name" data-translate="cloud_label">Cloudflare</h3>
  <span class="cf-status-label" data-translate="cloud_status_label">Working</span>
</div>
<div id="cf-host-status" class="cf-column cf-status-item cf-host-status cf-error-source">
    <i class="cf-icon cf-icon-server"></i>
    <i class="cf-icon-status cf-icon-error"></i>
  </div>
  <span class="cf-status-desc" data-translate="server_desc">api.thetvdb.com</span>
  <h3 class="cf-status-name" data-translate="server_label">Host</h3>
  <span class="cf-status-label" data-translate="server_status_label">Error</span>
</div>
                </div>
            </div>
        </div><!-- /.status-display -->
        <div class="cf-section cf-wrapper">
            <div class="cf-columns two">
                <div class="cf-column">
                    <h2 data-translate="what_happened">What happened?</h2>
                    <p data-translate="connection_timed_out">The initial connection between Cloudflare's network and the origin web server timed out. As a result, the web page can not be displayed.</p>
                </div>
                    <h2 data-translate="what_can_i_do">What can I do?</h2>
                          <h5 data-translate="if_website_visitor">If you're a visitor of this website:</h5>
      <p data-translate="try_again_in_a_few">Please try again in a few minutes.</p>
      <h5 data-translate="if_website_owner">If you're the owner of this website:</h5>
      <p><span data-translate="522_owner_desc">Contact your hosting provider letting them know your web server is not completing requests. An Error 522 means that the request was able to connect to your web server, but that the request didn't finish. The most likely cause is that something on your server is hogging resources.</span> <a href="https://support.cloudflare.com/hc/en-us/articles/200171906-Error-522" data-translate="addtl_troubleshooting">Additional troubleshooting information here.</a></p>
                </div>
            </div>
        </div><!-- /.section -->
        <div class="cf-error-footer cf-wrapper">
  <p>
    <span class="cf-footer-item">Cloudflare Ray ID: <strong>33b7e4718b9b5128</strong></span>
    <span class="cf-footer-separator">&bull;</span>
    <span class="cf-footer-item"><span data-translate="your_ip">Your IP</span>: 128.115.190.40</span>
    <span class="cf-footer-item"><span data-translate="performance_security_by">Performance & security by</span> <a data-orig-proto="https" data-orig-ref="www.cloudflare.com/5xx-error-landing?utm_source=error_footer" id="brand_link" target="_blank">Cloudflare</a></span>
  </p>
</div><!-- /.error-footer -->
    </div><!-- /#cf-error-details -->
</div><!-- /#cf-wrapper -->
thetvdb.com website appears to be overloaded. At least from my location in Southern California from which most of my attempts to during the last 5 days have been met with the display of either 404 (Not found) messages, or the Cloudfare’s snapshot image of the site. Every once in awhile I’ll be able to login, or enter a search, but the connection is always eventually interrupted after a few seconds, with the display of 404 or the snapshot.
