TheTVDB V3 - Post grade issues
If I change the season poster to the correct one, I get a blank poster frame. The current tv show seasons are available to select, yet none are displayed. (most recent update of PMS, deleted pulp-in support caches and metadata bundles, and also did a full metadata refresh.)
Plex Media Server Logs_2019-11-25_09-20-38.zip (5.8 MB) Plex Media Server Logs_2019-11-25_09-20-38.zip
Unrelated issue? Now I’m not getting any metadata at all. No text or anything, not just missing posters. “Episode 8” and similar instead of TVDB information.
Anyone else?
(Please note, these are properly named files and such, but it seems like the typical TVDB outage that happens frequently.)
It was working perfectly for me about 30 minutes ago, now it’s full of:
2019-11-25 14:53:01,512 (7fb2803bf700) : INFO (init:1073) - HTTP Error 403: Forbidden
2019-11-25 14:53:01,514 (7fb2803bf700) : DEBUG (networking:143) - Requesting ‘https://tvdb2.plex.tv/login
2019-11-25 14:53:01,615 (7fb24bfff700) : ERROR (networking:196) - Error opening URL ‘https://artworks.thetvdb.com/banners/_cache/posters/277165-6.jpg
and also getting no meta. Also assume it’s some sort of TVDB issue.
Everything seems to be working as expected here after stopping PMS service, deleting contents of cache folder, and restarting PMS service. Thanks for keeping us in the loop.
As of this morning for me, everything seems to be working again now as well. Thanks to all!
@ChuckPa: The issues I was having post-2058 update were fixed use @connor_greene’s fix in his thread (now unlisted).
I created another thread on this but I figured I would also post it here…
I have found a number of TV show series where they have changed the show year…
South Park (1997) is now South Park (1992)
there are others
This has caused a real mess with my automation, and explain why some times it wont match things correctly… I use the year in all my titles for both movies and TV shows since there are so many remake.
Please don’t create multiple threads. You’ll only make me go hunt it down and close it as a dupe :smiling_imp:
Hi All
Im still not getting the MetaData from TVDB.
Plex Docker via unRaid (Version 1.18.3.2129)[Plex Media Server
Please find the logs attached.
Plex Media Server Logs_2019-12-12_14-37-20.zip (5.1 MB)
What I already did:
  • Plex Dance
  • Deleted Cache
  • Updated to the current version
  • Rearranged the Agents in the Agents-Settings
  • Whitelisted TheTVDB on Network (just to be sure)
  • Rebtooted the whole unRaid instance
  • Checked the official Topic in Plexforum
I appreciate any kind of help regarding this issue.
Many Thanks
Cheers
Hi to All too,
I am too not getting any MetaData from TVDB.
Plex Media Server (Version 1.18.4.2171) on Windows
Plex Media Server Logs_2019-12-22_11-15-10.zip (4.2 MB)
What I already did:
  • Install Plex Media Server, Update to lastest Version
  • Create new library for TV Shows
  • Adding 1 show for testing
Many Thanks
Greets
Finally getting around to ripping seasons 5 - 9 of Seinfeld and Plex is not pulling in any metadata for any of the newly added episodes. Same setup as I have for seasons 1 - 4 which I ripped a couple of years ago and have metadata correctly setup. Will post logs after I complete the ripping process as right now they’re just filled with junk from that. Tried both TVDB and TMDB and I am not getting any metadata at all for the newly ripped episodes (just says Episode 1, 2 etc in Plex). My environment is PMS on Ubuntu 18.04
Using the default agent for the TV library section, I created new.
PMS 1.18.3.2175
Building this entirely new library section (I frequently delete and rebuild for testing) required about 25 minutes for some 11,300 episodes over my slow 40 Mbps internet.
Hi Chuckpa,
thanks for testing.
For me it’s still not working. Nor with my new PMS (Windows, Version 1.18.4.2171), neither with my old one (NVidia Shield TV, Version 1.18.4.2171).
The old PMS had successfully tagged over 30 series.
For testing, I have put one of the tagged series into a new library.
Plex Media Server Logs_2019-12-26_11-40-58.zip (5.4 MB)
Is there a problem with https://tvdb2.plex.tv/?
From the log:
“2019-12-26 08:50:56,091 (2fec62d4f0) : INFO (init:369) - Searching for exact match with: Season+01 (lang: en)
2019-12-26 08:50:56,106 (2fec62d4f0) : DEBUG (networking:143) - Requesting ‘https://tvdb2.plex.tv/login
2019-12-26 08:50:56,471 (2fec62d4f0) : DEBUG (networking:143) - Requesting ‘https://tvdb2.plex.tv/search/series?name=Season+01
2019-12-26 08:50:56,968 (2fec62d4f0) : ERROR (networking:196) - Error opening URL ‘https://tvdb2.plex.tv/search/series?name=Season+01
2019-12-26 08:50:56,969 (2fec62d4f0) : INFO (init:162) - HTTPError 404:
2019-12-26 08:50:56,970 (2fec62d4f0) : INFO (init:385) - There was a problem attempting an exact TVDB match in Season+01 (lang: en)”
Opening https://tvdb2.plex.tv/login with chrome delivers
“{“Error”:“Method not allowed”}”
I would expect an authorization error.
Any hints what I can do to make it work?
I also have tested one a friends PMS (QNAP, Version 1.18.4.2171). Same behavoir (Same internet provider, too).
Thanks angain and happy holidays
Cheers T.
The pasted log fragment shows the file naming is not correct for some reason.
series?name= should never return Season+01 bad structure here somewhere.
Did you add another top level directory but go one level too deep by accident?
Yes, it was one directory too deep.
And it was on purpose in order to test it with only one series…
But this was the crucial clue.
My files are /somepath/series/“age rating”/Name of the TV Show/Season 01/…
I only choosed the path “/somepath/series/” as library path. It works with the movies agent, but not with the tv agent.
Now selected multiple paths including the “age rating” part in library definition. :slight_smile:
Thanks again and a happy new year
T.
So I’ve moved from windows to ubuntu 18.04.3 and since then tvdb posters isn’t working anymore.
Movie posters are loading fine.
I’ve reset permissions correctly.
Removed the folder:
/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-in Support/Caches/com.plexapp.agents.thetvdb/
and tried refreshing meta but no success
cat com.plexapp.agents.thetvdb.log | grep ERROR
2020-01-24 15:43:18,058 (7f09837fe700) : ERROR (networking:196) - Error opening URL ‘https://meta.plex.tv/tv_e/80570/big+shots/2007
2020-01-24 15:43:19,026 (7f0983fff700) : ERROR (networking:196) - Error opening URL ‘https://tvdb2.plex.tv/series/253463/actors
2020-01-24 15:43:19,076 (7f0983fff700) : ERROR (networking:196) - Error opening URL ‘https://meta.plex.tv/tv_e/253463/black+mirror/2011
2020-01-24 15:43:29,168 (7f0982ffd700) : ERROR (networking:196) - Error opening URL ‘https://meta.plex.tv/tv_e/76736/blackadder/1983
2020-01-24 15:43:33,393 (7f099bfff700) : ERROR (networking:196) - Error opening URL ‘https://meta.plex.tv/tv_e/266189/blacklist/2013
2020-01-24 15:43:34,151 (7f0983fff700) : ERROR (networking:196) - Error opening URL ‘https://meta.plex.tv/tv_e/295647/blindspot/2015
2020-01-24 15:43:45,452 (7f0999417700) : ERROR (networking:196) - Error opening URL ‘https://meta.plex.tv/tv_e/295555/blood+and+oil/2015
2020-01-24 15:43:52,574 (7f0999c18700) : ERROR (networking:196) - Error opening URL ‘https://meta.plex.tv/tv_e/349310/bodyguard/2018
2020-01-24 15:43:57,330 (7f099bfff700) : ERROR (networking:196) - Error opening URL ‘https://meta.plex.tv/tv_e/75682/bones/2005
2020-01-24 15:44:01,434 (7f09817fa700) : ERROR (networking:196) - Error opening URL ‘https://meta.plex.tv/tv_e/81189/breaking+bad/2008
2020-01-24 15:44:04,006 (7f0999c18700) : ERROR (networking:196) - Error opening URL ‘https://meta.plex.tv/tv_e/219341/breakout+kings/2011
2020-01-24 15:44:19,034 (7f0999c18700) : ERROR (networking:196) - Error opening URL ‘https://meta.plex.tv/tv_e/80349/californication/2007
tailing the log gives me this:
2020-01-24 15:43:04,218 (7f09837fe700) : INFO (init:1022) - Season Extra XML is empty - therefore, no episode XML
2020-01-24 15:43:04,218 (7f09837fe700) : DEBUG (networking:143) - Requesting ‘https://tvdb2.plex.tv/episodes/7159758?lang=en
2020-01-24 15:43:04,245 (7f09827fc700) : DEBUG (networking:143) - Requesting ‘https://artworks.thetvdb.com/banners/episodes/80379/7128890.jpg
2020-01-24 15:43:04,257 (7f09827fc700) : INFO (init:1022) - Season Extra XML is empty - therefore, no episode XML
2020-01-24 15:43:04,259 (7f0999557700) : DEBUG (networking:143) - Requesting ‘https://artworks.thetvdb.com/banners/episodes/80379/7146880.jpg
2020-01-24 15:43:04,260 (7f09827fc700) : DEBUG (networking:143) - Requesting ‘https://tvdb2.plex.tv/episodes/7161279?lang=en
2020-01-24 15:43:04,269 (7f0999557700) : INFO (init:1022) - Season Extra XML is empty - therefore, no episode XML
2020-01-24 15:43:04,280 (7f0999557700) : DEBUG (networking:143) - Requesting ‘https://tvdb2.plex.tv/episodes/7177179?lang=en
2020-01-24 15:43:04,292 (7f0983fff700) : DEBUG (networking:175) - Not caching ‘https://artworks.thetvdb.com/banners/fanart/original/73545-27_t.jpg’ (content type ‘image/jpeg’ not cacheable in Agent plug-ins)
2020-01-24 15:43:04,299 (7f0998d56700) : DEBUG (networking:143) - Requesting ‘https://artworks.thetvdb.com/banners/episodes/80379/7153508.jpg
2020-01-24 15:43:04,312 (7f0998d56700) : INFO (init:1022) - Season Extra XML is empty - therefore, no episode XML
2020-01-24 15:43:04,312 (7f0983fff700) : DEBUG (networking:143) - Requesting ‘https://artworks.thetvdb.com/banners/fanart/original/73545-48_t.jpg
2020-01-24 15:43:04,326 (7f09837fe700) : DEBUG (networking:143) - Requesting ‘https://artworks.thetvdb.com/banners/episodes/80379/7159758.jpg
2020-01-24 15:43:04,336 (7f09837fe700) : INFO (init:1022) - Season Extra XML is empty - therefore, no episode XML
2020-01-24 15:43:04,390 (7f09827fc700) : DEBUG (networking:143) - Requesting ‘https://artworks.thetvdb.com/banners/episodes/80379/7161279.jpg
2020-01-24 15:43:04,400 (7f09827fc700) : INFO (init:1022) - Season Extra XML is empty - therefore, no episode XML
2020-01-24 15:43:04,404 (7f0999557700) : DEBUG (networking:143) - Requesting ‘https://artworks.thetvdb.com/banners/episodes/80379/7177179.jpg
2020-01-24 15:43:04,413 (7f0999557700) : INFO (init:1022) - Season Extra XML is empty - therefore, no episode XML
2020-01-24 15:43:04,415 (7f099affd700) : DEBUG (threadkit:244) - Parallel task set UpdateEpisodes ended
2020-01-24 15:43:04,419 (7f099affd700) : DEBUG (networking:143) - Requesting ‘https://tvdb2.plex.tv/series/80379/images?lang=en
2020-01-24 15:43:04,686 (7f099affd700) : DEBUG (networking:143) - Requesting ‘https://tvdb2.plex.tv/series/80379/images/query?keyType=fanart&lang=en
2020-01-24 15:43:04,991 (7f099bfff700) : DEBUG (networking:175) - Not caching ‘https://artworks.thetvdb.com/banners/fanart/original/273181-1_t.jpg’ (content type ‘image/jpeg’ not cacheable in Agent plug-ins)
Anywhere else to look ? Am I overlooking something ?
On version: Version 1.18.4.2171 With a plex pass
Yes. Also (with PMS stopped),
/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-in Support/Data/*
Hi thx for the swift reply.
Removed caches (only thetvdb agent)
And all data from Data/
Still no luck
MODERATOR EDIT Pruned.
Please gather the logs ZIP file.
Posting filtered snippets in the thread isn’t particularly helpful,
I still need look at what it is attempting to do; not what errors were returned.
Hi Chuck,
In attachment log files.
Logs.zip (5.6 MB)
