Tidal - Adding Songs To Server - Songs Title Not Matching
Hello
I’m having a bit of a weird issue
Whenever I play a song directly on the Tidal website => zero issue
When I play the same song on Plex directly through the Tidal source => zero issue
However whenever I add that album to my server (by right clicking and select the option “Add to My SERVER-NAME” and then play the same songs => then the issue comes up
And by issue I mean that the songs being played and the songs title are not matching at all
  • So instead of listening to song number 4 of that album, it’s actually song number 6 playing
  • And it does that randomly but for an insane amount of albums
Not sure what is causing this especially as when I play directly that same album through Plex (without adding it to my server), it plays perfectly fine, without any issues
Anyone has any idea as to what might be causing this please ?
Thanks in advance
Godspeed,
Sincerely,
Mawuena
By chance, is this happening for any album you add, or does that album happen to be multi-disc?
Hello
Ohh you’re right, it happens mostly when it’s multi disc albums
I say mostly because there are still one disc album for which is does happen
You’ve noticed that issue before on your side @Noah0504 ?
Thanks in advance
Yes, and the issue has been posted a few times, but never with a resolution.
I have this thread open:
Of course, if this is happening on single disc albums, then the issue may not be exactly the same!
