Tidal is not integrating with my music library
None of the features for tidal integrating with your music library are showing up for me no matter what app I use (android, plex. TV, Amazon fire, ps4)
I had some issues getting tidal to work. I unlinked it and then relinked it. I also signed out of all apps. I believe tidal is only working with the web app, iOS, Android.
You don’t list which versions of the apps you’re using but you must be on Plex Media Server 1.14.5470 or higher and on Plex Web head to the hosted app: https://app.plex.tv/desktop
All the version info is available here: https://support.plex.tv/articles/an-intro-to-tidal-with-plex/
Yep, the media server was the issue. I uninstalled it and downloaded the newest version. Works perfectly now
