Tmdb wrong year
Server Version#:latest
Player Version#: latest
Some movies have wrong year in metadata.
Using tmdb, as example, the goonies appears as a 2019 movie. On imdb it’s ok, but plex shows wrong year. Even refreshing metadata will not work.
Any idea about how to fix it?
I just double-checked and it worked ok for me (tested for English and German versions).
What language/country have you set for this library of yours?
It looks like somebody messed around with the entry by adding a 2019 release date for the Spanish version:
https://www.themoviedb.org/contribute
…and while you’re over there delete that 2019 - I mean C’mon… that’s just ignernt.
Spanish language. There are many movies with 2019 as release year :frowning:
Looks like you have some work to do - when you sign up.
(I love deleting that stuff - you will too)
(Note: when you add/change something it will be 24 hours before it’s available. ‘Refresh Metadata’ might change it. ‘Fix Match’ might change it. The Plex Dance will absolutely change it.)
Yeah, I already noticed, thanks guys.
Although on the website they show the right airing date, inside somebody decided to air “partial limited airing” whatever, on 2019. So I visited them and deleted all those “partial limited airing”.
I guess they decided to showcase them on a local cinema or something and some guy decided to add that, messing everything on tmdb…
