I’d like to know the preferred configuration for a wired ethernet connection from my Plex Server PC to the router. I have two routers. The first router is the Verizon FiOS service unit, and the second is a 5G router (Netgear) cabled to the Verizon router. I use the Netgear for wireless service in the house, since it has superior wireless capability over the Verizon router.
My Plex server is a fast Dell PC running Windows 10. My media library is stored on a Synology NAS box with four hard drives. All these devices are physically in the same room so easy to connect to either.
My question: is it better to connect the ethernet cables from the Plex server and the NAS to the Verizon router, or the Netgear router? Does it matter? Does using two routers in this way cause a “double NAT” problem?
I’m afraid the network information in the support pages is over my head technically, so I appreciate your help. Would like to get the physical connection correct before starting to troubleshoot the server and router settings.
Thank you!
