Too many Issues To Use in 15 Minutes
Server Version#: 1.18.9.2578
Player Version#: 7.23.0.13018
Tuner Make/Model: HDHR Connect
Guide/Lineup name:
Using XMLTV?:
Channel number/Name: All
I gave the DVR a try to see if it was improved.
Guide only goes out about 11 hours so I’m unable to select the shows I want to record.
Guide will not go back in the past. I needs to go back in time at least several hours. If you just missed a show you can’t go back in the guide and pick it.
When I pick a show and start recording, then go to the recording folder sorted by date added the show is not there.
Scheduled recordings I have deleted still show in the DVR schedule. Clicking them in the DVR schedule throws an unable to play file error.
Guide needs to indicate a show is recording. Red dot… With recordings not showing up in the folder and no indication they are recording I’m at a loss.
Recently received in my mail box.
Have you tried refreshing the guide? I’m not sure of exactly how much guide data is downloaded, but it’s at least 7-10 days worth.
I’m not really sure why you would need to do this. If you missed a show, what exactly are you going to be able to do with it?
It’s not going to move into your library until the recording is finished.
You mean shows that have already been recorded? They will stay in the DVR schedule. Shows that have not been recorded should be removed if you delete the the recording schedule.
It does. Or at least shows that are set to record will show a red dot. Other than that, you can head over to the DVR schedule and see active recordings.
