Trailer Button on pre-play not playing correct trailer
TLDR: For some time now when I hit the “Trailer” button in the pre-play screen of a movie it does not play the correct trailer. It plays the FIRST local Extra trailer which may be another movie’s trailer. I believe there’s a problem with the way the new movie agent loads online and local trailers. I also believe that the logic of the “Trailer” button simply plays the first extra relying on it being the first online Plex trailer. This error only occurs if you have online and local Extra trailers for a movie. If you only have online Extras it will not show up. If you remove local Extra trailers it also will not show up.
Server: Plex Media Server v1.24.3.5033 for Mac on macOS High Sierra 10.13.6
Libraries: Two separate movie libraries using the new “Plex Movie” scanner & agent and completely different files (no duplication)
Players:
  • Plex for Roku 6.9.8.7332-8ba9f346d-Plex on Roku Ultra 4640x RokuOS 10.5
  • Plex Preview for Roku 6.9.8.7332-8ba9f346d-PlexPreview on Roku Ultra 4640x RokuOS 10.5
  • Plex for Roku 6.9.4.7254-ac0e86853-Plex on Roku Ultra 4670x RokuOS 10.0
  • Plex Preview for Roku 6.9.8.7332-8ba9f346d-PlexPreview on Roku Ultra 4670x RokuOS 10.0
  • Plex web app v4.66.1 from app.plex.tv
  • Plex for Mac 1.35.1.2632-c6783c78 on macOS Big Sur 11.6
  • Plex for Mac 1.35.1.2632-c6783c78 on macOS High Sierra 10.13.6
In the first example movie, Take This Job and Shove It, I have ripped Extras including other movie trailers and loaded them into Plex. Show below:
All of these trailers are local Extras and load and play correctly when selected. When I select the “Trailer” button above though, it plays the “Body Slam Trailer” instead of the online Plex trailer for this movie. I do not believe that Plex has an online trailer for this movie as none is shown in the Extras list.
In the next example, Zombie Night, there IS an online Plex trailer for this movie and it is positioned AFTER the local Extras.
In this case the “Trailer” button does not play the online Plex trailer “Zombie Night” shown in the last Extra position but the first trailer which is a local Extra trailer for another movie.
In the final example, The Way Back, I tested removing local Extra trailers. In this screenshot you can see the three local Extras including two trailers are the first three listed Extras:
The problem is the same. Press the Trailer button and it plays the first Extra, the local Extra “Every Day Trailer”. Here are the files on disk:
Now I removed the two local Extra trailers from this directory and performed a “Refresh Metadata” on this movie:
Notice the order changed and moved the online Plex Trailer to the first position. Now the “Trailer” button plays the online Plex Trailer as expected.
This seems like a very reproducible buglet in the logic of the new movie scanner/agent.
Thank you, this has been my TED talk. :wink:
Chris
I think you are holding it wrong. :wink:
The trailers you can add into the folder of a movie are supposed to be trailers for that particular movie. Not for other movies.
That is the whole purpose of the “play trailer” button: to show you a teaser of the movie which you have selected on screen, to help decide whether you want to watch it right now.
If you are looking for a “cinema experience”, where you are shown one or several trailers of other movies, enable that in your particular Plex client: Why won't trailers or extras play? | Plex Support
Then simply press “Play”.
