When will xbox one support this? I made a awesome intro and I can't even use it! :(
doesn't work on
Roku3 / XBOX One
https://youtu.be/Q54Muv44XXY
My Pre-Roll Video
doesn't work on
Roku3 / XBOX One
My Pre-Roll Video
It is possible that it could be in the next update. The main missing component for trailers, playlists, etc was Play Queue implementation. And with the next update Dom has stated that video play queue support is included.
Of course, we won't know for sure until it makes it through certification (Or Dom spills more update secrets)
I really hope so! I tried to see if it worked on my browser but nothing shows up either! Did you get it to work?
this is a super neat feature!
Sadly, I haven't yet. I messed around with it when it was first introduced but then I didn't have a client that used it so when I migrated my server I didn't re-set it up... But if it starts working I might.
I really hope they get it up and rolling with the xbox one and roku
Same. I spent 6+ hour making a preroll in after effects and cant use it.
