Hi everyone, I just subscribed to Plex Pass, and correct me if I’m wrong, I thought one of the benefits was to get the option of trailers for the movies in my library, I restarted the app and re-signed in, but still don’t see it.
If you just subscribed, it helps to restart your server once, so it contacts plex.tv. This way it is made aware that your subscription status has changed.
If you want all the trailers and extras for movies which are already in your library, you need to refresh the movies/the library.
If you used TheMovieDatabase before to ‘match’ movies, there is also a small change in the agent configuration necessary:
Settings - Server - Agents - Movies - TheMovieDatabase
‘check’ the line ‘Plex Movie’
