I have two PMS boxes in two different geographical locations. Both run Windows 10 Pro x64 v1709, run version 1.10.1.4602 of PMS, have identical content libraries, similar resources (compute and memory, identical storage), and the same ISP (although different plans with different SLAs).
My issue is that since last week one server has stopped downloading the trailers and extras.
I have gone through everything I could think of including some things I searched here but I can’t figure out why this stopped working. Remediation steps I have performed are for example disabling IPv6 on the NIC, I’ve restarted all of the networking components, optimized the database and cleaned the bundles, and etc.
Focusing on one movie title in particular, the working server downloads the trailers and extras, has the content rating (PG-13) next to the watched status, and the audience rating from rotten tomatoes. The non-working server gets all of the metadata minus the trailers and extras, no content rating, and the audience rating from imdb.
Other observations have been that it has not been matching newly added TV shows, I have to manually select “match” and then it uses the auto-match with everything working as expected, and lastly in some instances I may have more than one copy of the same media in the same library. Historically when this happens the media is matched to the existing content and the existing content’s poster gets an icon with a number 2 in the upper left hand corner. Since this problem began the content is matched as entirely new content so there are now duplicate entries.
Based on that I would assume the Plex Media Agent is not working correctly and maybe this content is being matched with a different agent?
I’m not sure but regardless I’m not sure how to resolve it.
I wanted to add that if I perform a “Refresh Metadata” on content that already has trailers, extras, etc. they are removed. Not sure what’s happening here.
This is on ongoing problem. I have a few friends that are experiencing similar issues with their PMS. Some movies do load trailers and extras while the majority do not and many that already have the content if refreshed lose the additional content.
I’m glad to see I’m not alone but I would feel even better if the problem was acknowledged and actively worked on.
Same content, two different folders, two different libraries, same agent. The content from before the problem has everything correct as expected, the content scanned after the problem started is missing the trailers, extras, content rating, and rotten tomatoes audience rating.
With regards to the app, I don’t really follow what you mean here. I update and maintain my library via the WebUI/Web App. But any client used will also see the same results, different ratings, no extras etc. This could be an ATV4 or a Ruko (stick, ultra, 3, etc.). Maybe I misunderstood…
I’m also experiencing this same issue. All trailers and extras were present and loaded immediately after movies were added to library in the past. I tried to switch the Library Agent from “The Movie Database” (which had “Plex Movie” enabled and right after “The Movie Database”) to “Plex Movie” (which had “The Movie Database” enabled and right after “Plex Movie”). I made sure to change ratings dropdown in Plex Movie from The Movie Database to Rotten Tomatoes. This resulted in some movies getting Rotten Tomatoes ratings, most not, and some the ratings were lost all together. Essentially all of my trailers and extras were wiped out. I’ve tried switching back to The Movie Database agent, creating a brand new library, refreshing all metadata almost 20 times, restarting the server, clearing cache, emptying trash, cleaning bundles, and optimizing the database (why not) with no luck. In the brand new library I created, only a handful of movies picked up trailers, but it seems like every movie picked up “extras”. Between the two libraries, the same movie will have a trailer in one library and not the other. In the attached sample I cleanly started the server, tried to refresh metadata for The Dark Knight and Dunkirk. No trailers or extras appeared for The Dark Knight and only extras appeared for Dunkirk, but no trailer. Any ideas?
mulhearn1022, I did not make any changes to the agent settings or list hierarchy, this just started happening. You didn’t have an issue at all until you made changes?
At this point If I refresh the metadata on almost any movie I’ll lose the trailers and maybe the extras. In some cases the extras remain which is very odd.
@josebellas said:
This is now affecting both of my servers.
I just tried both movies again and was able to get the trailer for Dunkirk now but still not The Dark Knight. There seems to be very inconsistent performance here and tbh I’m not very confident that the trailers I currently have will stick around after subsequent Metadata Refreshes in the future.
Hey everyone - This thread was brought to my attention late yesterday evening, and I’m taking a look now. I apologize that you’re having trouble getting metadata for your movies. I’ll be looking through the posted logs and trying to debug this issue.
Ok, so it sounds like there may be a couple problems going on in this thread.
Issue 1: If everything about your movie looks good on plex.tv (it has a cast list, ratings, etc), EXCEPT that it is showing no trailers or extras, could you please do one of two things -
a) View the movie on a different client (like iOS) and see if there are trailers or extras available there
b) Post the information XML for the movie (Can be found here: https://support.plex.tv/articles/201998867-investigate-media-information-and-formats/ - look for “XML Information”)
Issue 2: If you are missing multiple things about the movie, like ratings, extras, content rating, etc. - please list the name of the title (and if you have the IMDb ID that’s helpful too)
My issue is number 1. I did as you recommended and checked for trailers on my iphone 7 and there is no trailer option. I’ve attached the xml file for the movie in question Alien Covenant
