trailers is unavailable help
hi have a trailers is unavailable on my atv3
i have try every thing
i think its a certificates problem
need help
plexconnect is 192.168.0.111
plexserver    is 192.168.0.111
atv is is 192.168.0.66
[PlexConnect]
enable_plexgdm = True
ip_pms = 192.168.178.10
port_pms = 32400
enable_dnsserver = True
port_dnsserver = 53
ip_dnsmaster = 8.8.8.8
prevent_atv_update = True
enable_plexconnect_autodetect = True
ip_plexconnect = 0.0.0.0
hosttointercept = trailers.apple.com
port_webserver = 80
enable_webserver_ssl = True
port_ssl = 443
certfile = ./assets/certificates/trailers.pem
loglevel = High
logpath = .
20:00:17 PlexConnect: started: 20:00:17
20:00:17 PlexConnect: Version: 0.3.1+
20:00:17 PlexConnect: Python: 2.7.6 (default, Feb 26 2014, 12:01:28)
[GCC 4.8.2 20140206 (prerelease)]
20:00:17 PlexConnect: Host OS: linux2
20:00:17 Settings: getsetting enable_plexconnect_autodetect=True
20:00:17 PlexConnect: IP_self: 192.168.0.111
20:00:17 Settings: getsetting hosttointercept=trailers.apple.com
20:00:17 Settings: getsetting enable_dnsserver=True
20:00:17 DNSServer: started: 20:00:17
20:00:17 Settings: getsetting port_dnsserver=53
20:00:17 Settings: getsetting ip_dnsmaster=8.8.8.8
20:00:17 Settings: getsetting prevent_atv_update=True
20:00:17 DNSServer: ***
20:00:17 DNSServer: DNSServer: Serving DNS on 192.168.0.111 port 53.
20:00:17 DNSServer: intercept: ['trailers.apple.com'] => 192.168.0.111
20:00:17 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
20:00:17 DNSServer: forward other to higher level DNS: 8.8.8.8
20:00:17 WebServer: started: 20:00:17
20:00:17 Settings: getsetting port_webserver=80
20:00:17 WebServer: ***
20:00:17 WebServer: WebServer: Serving HTTP on 192.168.0.111 port 80.
20:00:17 ATVSettings: init class CATVSettings
20:00:17 ATVSettings: load settings
20:00:17 Settings: getsetting enable_webserver_ssl=True
20:00:17 Settings: getsetting port_ssl=443
20:00:17 Settings: getsetting certfile=./assets/certificates/trailers.pem
20:00:17 WebServer: WebServer: Serving HTTPS on 192.168.0.111 port 443.
20:00:48 DNSServer: DNS request received!
20:00:48 DNSServer: Source: ('192.168.0.66', 52310)
20:00:48 DNSServer: Domain: ax.init.itunes.apple.com
20:00:48 DNSServer: ***forward request
20:00:53 DNSServer: DNS request received!
20:00:53 DNSServer: Source: ('192.168.0.66', 52310)
20:00:53 DNSServer: Domain: ax.init.itunes.apple.com
20:00:53 DNSServer: ***forward request
20:00:53 DNSServer: -> DNS response from higher level
20:00:53 DNSServer: Source: ('192.168.0.66', 58387)
20:00:53 DNSServer: Domain: e8076.e9.akamaiedge.net
20:00:54 DNSServer: -> DNS response from higher level
20:00:54 DNSServer: DNS request received!
20:00:54 DNSServer: Source: ('192.168.0.66', 52310)
20:00:54 DNSServer: Domain: ax.init.itunes.apple.com
20:00:54 DNSServer: ***forward request
20:00:54 DNSServer: Source: ('192.168.0.66', 58387)
20:00:54 DNSServer: Domain: e8076.e9.akamaiedge.net
20:00:54 DNSServer: Source: ('192.168.0.66', 59949)
20:00:54 DNSServer: Domain: p45-buy.itunes.apple.com.akadns.net
20:01:03 DNSServer: DNS request received!
20:01:03 DNSServer: Source: ('192.168.0.66', 55780)
20:01:03 DNSServer: Domain: itunes.apple.com
20:01:03 DNSServer: ***forward request
20:01:08 DNSServer: DNS request received!
20:01:08 DNSServer: Source: ('192.168.0.66', 55780)
20:01:08 DNSServer: Domain: itunes.apple.com
20:01:08 DNSServer: ***forward request
20:01:08 DNSServer: -> DNS response from higher level
20:01:37 DNSServer: DNS request received!
20:01:37 DNSServer: Source: ('192.168.0.66', 62061)
20:01:37 DNSServer: Domain: time.apple.com
20:01:37 DNSServer: ***forward request
20:01:37 DNSServer: -> DNS response from higher level
20:01:37 DNSServer: Source: ('192.168.0.66', 61474)
20:01:37 DNSServer: Domain: mesu.apple.com
20:01:37 DNSServer: ***restrain request
20:01:37 DNSServer: -> DNS response: 192.168.0.111
20:01:37 DNSServer: Source: ('192.168.0.66', 58323)
20:01:37 DNSServer: Domain: data.iana.org
20:01:38 DNSServer: DNS request received!
20:01:38 DNSServer: Source: ('192.168.0.66', 58030)
20:01:38 DNSServer: Domain: ax.init.itunes.apple.com
20:01:38 DNSServer: ***forward request
20:01:38 DNSServer: -> DNS response from higher level
20:01:39 DNSServer: DNS request received!
20:01:39 DNSServer: Source: ('192.168.0.66', 57097)
20:01:39 DNSServer: Domain: itunes.apple.com
20:01:39 DNSServer: ***forward request
20:01:39 DNSServer: -> DNS response from higher level
20:01:39 DNSServer: Source: ('192.168.0.66', 54580)
20:01:39 DNSServer: Domain: p45-buy.itunes.apple.com
20:01:44 DNSServer: DNS request received!
20:01:44 DNSServer: Source: ('192.168.0.66', 54580)
20:01:44 DNSServer: Domain: p45-buy.itunes.apple.com
20:01:44 DNSServer: ***forward request
20:01:45 DNSServer: -> DNS response from higher level
20:01:45 DNSServer: DNS request received!
20:01:45 DNSServer: Source: ('192.168.0.66', 59729)
20:01:45 DNSServer: Domain: configuration.apple.com
20:01:45 DNSServer: ***forward request
20:01:45 DNSServer: Source: ('192.168.0.66', 54580)
20:01:45 DNSServer: Domain: p45-buy.itunes.apple.com
20:01:45 DNSServer: Source: ('192.168.0.66', 63467)
20:01:45 DNSServer: Domain: a2.mzstatic.com
20:01:45 DNSServer: Source: ('192.168.0.66', 56305)
20:01:45 DNSServer: Domain: a3.mzstatic.com
20:01:46 DNSServer: -> DNS response from higher level
20:01:46 DNSServer: DNS request received!
20:01:46 DNSServer: Source: ('192.168.0.66', 49708)
20:01:46 DNSServer: Domain: a5.mzstatic.com
20:01:46 DNSServer: ***forward request
20:01:46 DNSServer: Source: ('192.168.0.66', 56342)
20:01:46 DNSServer: Domain: a1.mzstatic.com
20:01:46 DNSServer: Source: ('192.168.0.66', 51756)
20:01:46 DNSServer: Domain: a4.mzstatic.com
20:01:46 DNSServer: Source: ('192.168.0.66', 63467)
20:01:46 DNSServer: Domain: a2.mzstatic.com
20:01:47 DNSServer: -> DNS response from higher level
20:01:47 DNSServer: DNS request received!
20:01:47 DNSServer: Source: ('192.168.0.66', 56305)
20:01:47 DNSServer: Domain: a3.mzstatic.com
20:01:47 DNSServer: ***forward request
20:01:47 DNSServer: Source: ('192.168.0.66', 49708)
20:01:47 DNSServer: Domain: a5.mzstatic.com
20:01:47 DNSServer: Source: ('192.168.0.66', 56342)
20:01:47 DNSServer: Domain: a1.mzstatic.com
20:01:47 DNSServer: Source: ('192.168.0.66', 51756)
20:01:47 DNSServer: Domain: a4.mzstatic.com
20:01:47 DNSServer: Source: ('192.168.0.66', 60620)
20:01:47 DNSServer: Domain: init-p01st.push.apple.com
20:01:47 DNSServer: Source: ('192.168.0.66', 52696)
20:01:47 DNSServer: Domain: 9-courier.push.apple.com
20:01:48 DNSServer: -> DNS response from higher level
20:01:49 DNSServer: DNS request received!
20:01:49 DNSServer: Source: ('192.168.0.66', 62723)
20:01:49 DNSServer: Domain: trailers.apple.com
20:01:49 DNSServer: ***intercept request
20:01:49 DNSServer: -> DNS response: 192.168.0.111
20:01:50 DNSServer: DNS request received!
20:01:50 DNSServer: Source: ('192.168.0.66', 54261)
20:01:50 DNSServer: Domain: init.itunes.apple.com
20:01:50 DNSServer: ***forward request
20:01:50 DNSServer: -> DNS response from higher level
20:01:50 DNSServer: Source: ('192.168.0.66', 63635)
20:01:50 DNSServer: Domain: se.itunes.apple.com
20:01:51 DNSServer: -> DNS response from higher level
20:01:52 DNSServer: DNS request received!
20:01:52 DNSServer: Source: ('192.168.0.66', 61517)
20:01:52 DNSServer: Domain: play.itunes.apple.com
20:01:52 DNSServer: ***forward request
20:01:52 DNSServer: -> DNS response from higher level
20:01:53 DNSServer: DNS request received!
20:01:53 DNSServer: Source: ('192.168.0.66', 49427)
20:01:53 DNSServer: Domain: pd-st.itunes.apple.com
20:01:53 DNSServer: ***forward request
20:01:54 DNSServer: -> DNS response from higher level
20:02:40 PlexConnect: Shutting down.
20:02:41 WebServer: Shutting down.
20:02:41 ATVSettings: save settings
20:02:44 DNSServer: Shutting down.
20:02:44 PlexConnect: shutdown
Everything? I wonder, how we could help then...
:-D
Edit: "How" did you generate/transfer your certs?
:-D
thanks for that i had used the different certs  nz and us certs which did not match :P
