Trailers Not Available Setup Problems
Sorry, another one of the trailers not available posts :(
I'm running PlexConnect from the 1st September and PMS version 0.9.8.5 on the same Windows 7 Ultimate box 192.168.1.82.  Python is version 2.7.5.  ATV is ATV3 version 5.3(6105).  I'm in the UK.
My settings.cfg -
[PlexConnect]
logpath = .
enable_dnsserver = True
ip_webserver = 0.0.0.0
prevent_atv_update = True
port_dnsserver = 53
enable_plexconnect_autodetect = True
port_pms = 32400
port_webserver = 80
ip_plexconnect = 0.0.0.0
certfile = C:\PlexConnect\assets\certificates railers.pem
ip_dnsmaster = 8.8.8.8
loglevel = Normal
ip_pms = 192.168.178.10
enable_plexgdm = True
port_ssl = 443
Link to my log - http://pastebin.com/2GS1JwAz
I followed the instructions on installing the certificate from a Windows machine but no luck.  I noticed something, it may be nothing, in the console of the iPhone Configuration Utility under the AppleTV console when I was installing the certificate on it -
Dec 31 16:01:38 Apple-TV mc_mobile_tunnel[87] : (Note ) MC: mc_mobile_tunnel starting.
Dec 31 16:01:38 Apple-TV profiled[60] : (Note ) MC: Profile fix12 queued for installation.
Dec 31 16:01:38 Apple-TV mc_mobile_tunnel[87] : (Note ) MC: mc_mobile_tunnel shutting down.
Dec 31 16:01:38 Apple-TV profiled[60] : (Note ) MC: Checking for MDM installation...
Dec 31 16:01:38 Apple-TV profiled[60] : (Note ) MC: ...finished checking for MDM installation.
Dec 31 16:01:38 Apple-TV profiled[60] : (Note ) MC: Beginning profile installation...
Dec 31 16:01:38 Apple-TV profiled[60] : Dec 31 16:01:38  SecTrustEvaluate  [leaf AnchorTrusted]
Dec 31 16:01:38 Apple-TV profiled[60] : (Note ) MC: Profile fix12 installed.
Dec 31 16:01:38 Apple-TV awdd[88] : libMobileGestalt copySystemVersionDictionaryValue: Could not lookup ReleaseType from system version dictionary
Dec 31 16:01:38 Apple-TV awdd[88] : CoreLocation: CLClient is deprecated. Will be obsolete soon.
Dec 31 16:01:38 Apple-TV mc_mobile_tunnel[89] : (Note ) MC: mc_mobile_tunnel starting.
Dec 31 16:01:38 Apple-TV mc_mobile_tunnel[89] : (Note ) MC: mc_mobile_tunnel shutting down.
Dec 31 16:01:39 Apple-TV mc_mobile_tunnel[90] : (Note ) MC: mc_mobile_tunnel starting.
Dec 31 16:01:39 Apple-TV mc_mobile_tunnel[90] : (Note ) MC: mc_mobile_tunnel shutting down.
Also, when I click on the Trailers icon it reports the following to the console -
Sep  3 10:01:29 Apple-TV AppleTV[68] : Sep  3 10:01:29  SecTrustEvaluate  [leaf ValidLeaf ValidRoot]
I did a bit of digging and apparently that error is a trust issue with self signed certificates.  It might be a red herring but anyone have any ideas what could be wrong?
Hmm, do you use your own root ca cert, which also installed in ATV config file, to sign your pem? like you run your own openssl command to generate ca cert and use the same cert to sign the pem?
No, I was following the instructions in this post http://forums.plexapp.com/index.php/topic/79540-windows-specific-instructions-for-creating-and-installing-the-ssl-cert/.  However, I started again on another Windows 7 PC and when finished I installed the certificate on my original PlexConnect PC and all is working.  Something on the original PC must have been making it create a dodgy certificate.
