Trailers not playing
Hi
My movie trailers aren't working. I have several movie trailers locally stored and they show up on the movies' page. When I click to play the trailer nothing happens. They do work on my PC/Android App though. Tried several ones. I'm using the Plex Black Edition skin. It works fine in the normal Plex skin though.
Hi
Suggest checking the Plex Inc Support pages for trailers an extras and make sure you have set them up properly.
Regards
Everything is setup properly. I can start them when I use the android app and cast to the Raspberry Pi, but I can't start it directly from the Pi.
You have set the number of trailers in Rasplex Preferences, default is 0, therefore no trailers will play!
I'm talking about movie trailers I have on my server. If I go to a movie's page and click "play trailer" of that specific movie it isn't playing. It does play trailers before movies.
