Trailers Unavailable. Help needed getting PC to work.
I've gotten PC to work properly before using an UNRAID unit. I'm trying to set it up for a friend who has pretty much same setup with UNRAID unit but I'm running into new issues.
I can access all content on my ATV except for trailers. When I click on trailers I get an error saying that Trailers is currently unavailable and to try again later. I've tried restarting my Plex Connect plunging and completely powering on and off my ATV. I believe everything is installed correctly.
ATV 6.2.1 DNS 10.0.1.18
Plex Connect is installed on an UNRAID 6.0-beta10a unit at 10.0.1.18
PMS v 0.9.11.1.678-c48ffd2 Installed on the UNRAID unit at 10.0.1.18
The certificate files have been placed into the PC certificates folder
I installed the profile to the ATV manually using iPhone configuration utility.
[PlexConnect]
enable_plexgdm = True
ip_pms = 192.168.178.10
port_pms = 32400
enable_dnsserver = True
port_dnsserver = 53
ip_dnsmaster = 8.8.8.8
prevent_atv_update = True
enable_plexconnect_autodetect = True
ip_plexconnect = 0.0.0.0
hosttointercept = trailers.apple.com
port_webserver = 80
enable_webserver_ssl = True
port_ssl = 443
certfile = ./assets/certificates/trailers.pem
loglevel = Normal
logpath = .
![post-2268-0-49068500-1416335193.png|690x223](upload://hDWh4IQfM1KXdq1lZo8Stc6auAh.png)
EDIT: I think I got it to work. I deleted the ATV profile i created with the iPhone configurator and did the automatic creation over wifi and now things seem to be working.
